Occasionsal engine skip - Ford Powerstroke Diesel Forum
post #1 of 6 Old 06-02-2006, 08:06 AM Thread Starter
Could someone give me some help in determining what might cause an intermittant engine skip in my '02 F250? I've gotten one skip three times in the past two weeks. Two were at highway speeds and one was during idle. At the idle skip, the truck cut off but immediately restarted. No check engine light. The engine only skips once and then goes away so it's not a series of skips. Thanks. Y8
y8earp is offline
post #2 of 6 Old 06-02-2006, 01:53 PM
it could be a cam sensor starting to go, but unfortunatly without a code or the truck in front of me doing it, there are a ton of other things it could be........Marc
mschn99 is offline
post #3 of 6 Old 06-02-2006, 04:16 PM Thread Starter
Thanks, Marc. I have no idea what a cam sensor is but it sounds serious to me.
y8earp is offline
post #4 of 6 Old 06-02-2006, 07:04 PM
a cam sensor is a very easy repair.........usually it causes the motor to die....it may or may not restart, and the problem will happen agian and again....eventually it will not start.
sometimes you see them that they act up early and cause a miss or skipp.....its not common, but its a possibility....
where your truck had a check engine light on.....the best way to start is go down to autozone or somewhere like that and get the codes....get back to me and we will attempt to figure it out..........Marc
mschn99 is offline
post #5 of 6 Old 06-03-2006, 01:56 AM Thread Starter
Thanks for you help, Marc. I will do that. As of now, I don't have a check engine light though.
y8earp is offline
post #6 of 6 Old 06-03-2006, 10:22 AM
99Smokin73Stroker's Avatar
Send a message via AIM to 99Smokin73Stroker Send a message via Yahoo to 99Smokin73Stroker
Mine did that a few times too just before I sold it. I had replaced the cam sensor about 20k before.....they're not fun when they go out cuz they pick the worst times to leave you stranded. It's always a good idea to have an extra one in your glove box....
2005 F350 XLT FX4. 2.5" leveling kit, 03 turbo, 4" MBRP Turbo-back, 58v FICM, SCT X4, Irate Diesel coolant filter
99Smokin73Stroker is offline
