Question about DIY intake system???????? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 08-07-2007, 03:24 PM Thread Starter
Question Question about DIY intake system????????
I put together my DIY intake today. Napa 6637 filter and 3" of 4" pipe. Removed factory air box. I have a few questions. My 1st question is how can I keep the intake tube from kinking . I was able to get it to only be slightly oval but I feel like it could kink at any moment. Also I notice slightly more turbo whine is this normal? Lastly how can I check for leaks around the connections? I did notice an increase in power in the higher rpm range and feel like the engine will be able to breath much better with this filter.
(99' 7.3 F350 4x4 single rear wheel)
jejjackson is offline
post #2 of 4 Old 08-07-2007, 03:34 PM
worx's Avatar
Send a message via Yahoo to worx
I would fill the tube with some clean shop rags to act as a filler- when your done shaping, just pull them out... I think the whine is from the lack of silencing function that the stock box does- you'll get used to it and enjoy it!
Leaks- maybe try some warm water or washer fluid around the connection and see if its sucked dry? I am at a little loss on that one...
2001 F250 SD 4x4 Short box 7.3l
Walker Exhaust, AFE Stage 1 filter
Van Aaken 4 Bank/4 Pos Chip from DJs
Snow Stage 2 Water Meth- 13 gal tank
Rebuilt and Tugger upgraded tranny/converter
Autometer 3 Gauge Cluster
Grill guard, Nerf Bars, Headache rack
LED Lightbar, LED Lights and Siren, CB and VHF Radios
Removable Roof Wing behind Lightbar
Toughbook CF-28 w/Touchscreen for GPS and Internet
Zoodad Mod
256K and sat for the year!
worx is offline
post #3 of 4 Old 08-07-2007, 04:19 PM
COLLEGE KID
lifewitlooie's Avatar
Send a message via AIM to lifewitlooie
if it looks like it might leak... use duct tape!!
lifewitlooie is offline
post #4 of 4 Old 08-07-2007, 04:27 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
IF i remember right on the early 99's to get it to sit right you had to turn the rubber intake tube a little to avoid the pipe kinking
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
