my oasis not bad for a early 99
VIN VEH LINE MKT DERIV BODY CAB VER SERIES DRIVE TYPE PLT CD TRS CD ENG CD PROD DATE WARR DATE SELLING DEALER SELL CNT TIS WCC CPSC_6 PREF BASE SUFF CCC CD DIST(Miles)
1FTSF31F0XEA68680 T/F7 F T/BB T/CD T/E A1 T/VF T/DS 02-APR-1998 27-JUN-1998 147093 USA 0 * * * * * * * 5 AWS Claim Key: 50079 Trx Code: 98S16 Labor Hrs: 0.2 Dlr Cd-Sub Cd: 04726 - * Name: ADVANTAGE FORD-LINC-MERC INC Ph: 765-8250594 St:IN Ctry Cd: USA Reg Cd: NA Repr Date:26-MAY-1998 Doc #:14502001 1FTSF31F0XEA68680 T/F7 F T/BB T/CD T/E A1 T/VF T/DS 02-APR-1998 27-JUN-1998 147093 USA 7 7S22 180106 F58Z 14526 A D02 42 4512 AWS Claim Key: 612445 Trx Code: S07 Labor Hrs: 2 Dlr Cd-Sub Cd: 02901 - * Name: DON MEYER FORD-MERCURY, INC. Ph: 812-6637621 St:IN Ctry Cd: USA Reg Cd: NA Repr Date:28-DEC-1998 Doc #:028302A Cust Comments: DIED WHILE DDRIVING CRANKS GOOD WONT START TOWED IN Tech Comments: EEC TEST NO CODES OUTPUT PINPOINT TEST A 1 A6 FUSE BLOWN TO PCM RELAY BAD 10 AMP FUSE INSTALLED D INSTEAD OF 30 AMP FUSE REPLACE FUSE MANUAL MISLEADTESTING PROCESS 1FTSF31F0XEA68680 T/F7 F T/BB T/CD T/E A1 T/VF T/DS 02-APR-1998 27-JUN-1998 147093 USA 7 * * * * * * * 4512 AWS Claim Key: 612446 Trx Code: 98S17 Labor Hrs: 0.3 Dlr Cd-Sub Cd: 02901 - * Name: DON MEYER FORD-MERCURY, INC. Ph: 812-6637621 St:IN Ctry Cd: USA Reg Cd: NA Repr Date:28-DEC-1998 Doc #:028302B Cust Comments: RECALL 98S17 LOWER STEERING SHAFT Tech Comments: PERFORM RECALL ON LOWER SHAFT INSPECTION 1FTSF31F0XEA68680 T/F7 F T/BB T/CD T/E A1 T/VF T/DS 02-APR-1998 27-JUN-1998 147093 USA 10 4A01 080102 F81Z 7550 HB P09 42 7632 AWS Claim Key: 1563120 Trx Code: 2 Labor Hrs: 3.7 Dlr Cd-Sub Cd: 02901 - * Name: DON MEYER FORD-MERCURY, INC. Ph: 812-6637621 St:IN Ctry Cd: USA Reg Cd: NA Repr Date:02-APR-1999 Doc #:031199A Cust Comments: TRUCK HAS TROUBLE GOING INTO REVERSE. TRUCK IS STUCK BETWEEN GEARS. CUST WAS DOWNSHIFTING FROM 5TH TO 4TH GEAR AND THEN VEHICLE GOT STUCK IN GEAR. MOTOR IS RUNNING BUT TRUCK SOUNDS LIKE Tech Comments: CLUTCH WIL NOT DISENGAGE. TRANS OK. TOOK OUT SLAVE CYLINDER AND FOUND FRICTION MATERIAREPLACED CLUTCH AND PRESSURE PLATE 1FTSF31F0XEA68680 T/F7 F T/BB T/CD T/E A1 T/VF T/DS 02-APR-1998 27-JUN-1998 147093 USA 18 7C01 17XXXX * 14018 * L29 07 11256 AWS Claim Key: 5914850 Trx Code: E83 Labor Hrs: 0.8 Dlr Cd-Sub Cd: 04290 - * Name: MATLOCK FORD-MERCURY Ph: 317-7365185 St:IN Ctry Cd: USA Reg Cd: NA Repr Date:19-NOV-1999 Doc #:00904401 1FTSF31F0XEA68680 T/F7 F T/BB T/CD T/E A1 T/VF T/DS 02-APR-1998 27-JUN-1998 147093 USA 19 7S22 1801XX F2UZ 14526 M L29 46 12850 AWS Claim Key: 6334292 Trx Code: S07 Labor Hrs: 0.5 Dlr Cd-Sub Cd: 04290 - * Name: MATLOCK FORD-MERCURY Ph: 317-7365185 St:IN Ctry Cd: USA Reg Cd: NA Repr Date:20-DEC-1999 Doc #:00925001 Tech Comments: TIME TO REPLACE THE FUSE ASSY 1FTSF31F0XEA68680 T/F7 F T/BB T/CD T/E A1 T/VF T/DS 02-APR-1998 27-JUN-1998 147093 USA 27 7C01 170503 XF1Z 14018 BA L29 28 27567 AWS Claim Key: 11278374 Trx Code: E83 Labor Hrs: 1.1 Dlr Cd-Sub Cd: 04290 - * Name: MATLOCK FORD-MERCURY Ph: 317-7365185 St:IN Ctry Cd: USA Reg Cd: NA Repr Date:24-AUG-2000 Doc #:02924301 Tech Comments: REPLACE THE DOOR SWITCH 1FTSF31F0XEA68680 T/F7 F T/BB T/CD T/E A1 T/VF T/DS 02-APR-1998 27-JUN-1998 147093 USA 30 6L05 011201 YC3Z 2513560 CAD T90 01 33963 AWS Claim Key: 13427153 Trx Code: E84 Labor Hrs: 0.2 Dlr Cd-Sub Cd: 04290 - * Name: MATLOCK FORD-MERCURY Ph: 317-7365185 St:IN Ctry Cd: USA Reg Cd: NA Repr Date:09-DEC-2000 Doc #:00711801 Tech Comments: REPL THE CUPHOLDER ASSY 1FTSF31F0XEA68680 T/F7 F T/BB T/CD T/E A1 T/VF T/DS 02-APR-1998 27-JUN-1998 147093 USA 58 * * * * * * * 89227 AWS Claim Key: 22161497 Trx Code: 02S34 Labor Hrs: 1.4 Dlr Cd-Sub Cd: 04728 - * Name: RAY SKILLMAN PERFORMANCE FORD Ph: 317-8812541 St:IN Ctry Cd: USA Reg Cd: NA Repr Date:04-MAR-2003 Doc #:04961540 Cust Comments: 02S34 PARKING BRAKE FRONT CABLE AND CONTROL Tech Comments: RECALL RECALL 1FTSF31F0XEA68680 T/F7 F T/BB T/CD T/E A1 T/VF T/DS 02-APR-1998 27-JUN-1998 147093 USA 58 * * * * * * * 89227 AWS Claim Key: 22161498 Trx Code: 99S32 Labor Hrs: 0.6 Dlr Cd-Sub Cd: 04728 - * Name: RAY SKILLMAN PERFORMANCE FORD Ph: 317-8812541 St:IN Ctry Cd: USA Reg Cd: NA Repr Date:04-MAR-2003 Doc #:04961541 Cust Comments: 99S32 FUEL SYSTEM INTEGRITY Tech Comments: RECALL RECALL 1FTSF31F0XEA68680 T/F7 F T/BB T/CD T/E A1 T/VF T/DS 02-APR-1998 27-JUN-1998 147093 USA 58 2E01 030008 XC3Z 9E527 AARM D36 42 89227 AWS Claim Key: 22161499 Trx Code: E72 Labor Hrs: 3.4 Dlr Cd-Sub Cd: 04728 - * Name: RAY SKILLMAN PERFORMANCE FORD Ph: 317-8812541 St:IN Ctry Cd: USA Reg Cd: NA Repr Date:04-MAR-2003 Doc #:04961551 Cust Comments: D A ENGINE MISSES AT IDLE AND ACCEL. (INJ.#8 HAS BEEN REPLACED) Tech Comments: MT; TIME TO DIAG AND REPAIR. |
looks good to me, i guess......j/k!
