Front main seal replacement/ 96 7.3 - Ford Powerstroke Diesel Forum
post #1 of 3 Old 05-30-2011, 05:34 PM Thread Starter
going to do this any shortcuts or things I should be aware of....Except the obvious ...
shawpdx1 is offline
post #2 of 3 Old 06-07-2011, 07:56 PM
sethc24's Avatar
Are you talking about the crankshaft seal?. If you are i know when i did mine on my 2000 f250 7.3 psd, you have to replace the wear sleeve as well as the crankshaft seal. Because the original seal wears a groove into the sleeve and if you try and reuse it the new seal will leak. When i bought a crankshaft seal from ford and the new wear seal was included. Basically you need a 3 jaw puller to remove the old sleeve and a socket the same diameter as the sleeve and a hammer to reinstall it.
1997 F-250 4x4. 5 speed
, 6637,exhaust,dp-tuner,dana 60, 33's
sethc24 is offline
post #3 of 3 Old 06-08-2011, 04:16 AM Thread Starter
Thanks for info, Yeah I got everything for it, Its not leaking bad just doing PM on it.
shawpdx1 is offline
