Where can I find the Optix Dipricol gauges - Ford Powerstroke Diesel Forum
Old 05-16-2011, 01:40 PM
That's what she said!
Im looking for the optix Dipricol gauges and I cant seem to find them anywhere, and if not im thinking the isspros but not sure what the mail difference is between the EV and the EV2.
Thanks
Old 05-17-2011, 10:06 AM
Feedback Score: 5 reviews
We stoped selling the Dipricol gauges to many problems. We sell Isspro and Autometer kits.
EV1's:
EV instruments have the following standard features:
Black dished face dial, white backlit numerals, illuminated white (or red/org.) pointer and black brass low-profile bezel on Automotive series.
White dished face dial, green backlit numerals, illuminated red/org. pointer and black brass low-profile bezel on their latest series of Automotive gauges.
White dished face dial, blue backlit numerals, illuminated blue pointer and chromed brass low-profile bezel on Marine series.
Convex scratch-resistant glass lenses. Exception: domed polycarbonate crystal lenses on trip odometer speedometers and memory and internal shift-lite tachometers.
Anti-fog solution applied to inside of glass lenses.
All instruments frontally sealed.
All outer plastic parts are UV stabilized.
Glass filled white polyester case resists corrosion and vibration, augments lighting designed for superior night time viewing.
All electrical Gauges feature air core movements
EV2's:
• All are microprocessor controlled stepper motor driven for the utmost in accuracy.
• No amplifier boxes - just one simple wiring connector on the back of each gauge.
• All gauges utilize a weatherpack connector for their sensors.
• All gauges feature a full 270 degree needle sweep.
• Fuel pressure gauges utilize a robust electric sensor selected specifically for diesel applications. No isolator is needed. Just Plug and Play.
• Each gauges uses LED lighting. Pointers also illuminate.
• Separate dimmer in R-72022 wiring harness allows for calibration of illumination with factory instruments. Gauges will dim with the adjustment of your factory dimmer, but this separate dimmer allows for fine tuning to match brightness.
• Largest selection of different gauges.
• Assembled in the USA!!!
