cam position sensor problem - Ford Powerstroke Diesel Forum
Old 07-31-2007, 10:59 AM
Question cam position sensor problem
I have a 02 psd. Replaced two cps's within a week. what could be causing the sensor to short out??
Old 07-31-2007, 11:04 AM
HardLuck Case of the Year
Send a message via AIM to Ditty Send a message via Yahoo to Ditty
Are you getting them at the Dealer? If not...I would try there. They're $30-ish bucks!
Old 07-31-2007, 11:07 AM
bought cps (2) through dealer
bought both cam position sensors through the dealer. One was black one was blue. Herd different colors mean different things?
Old 07-31-2007, 11:08 AM
duct tape & zip ties
Are you sure it is the cps and not an idm or injector, or fuel pump, or uvc ( under valve cover wiring harness) problem that could be causing you to think it is the cps.
I can see getting a bad sensor but to get 2 in the same week. Seems like there would be something else wrong with the truck.
Old 07-31-2007, 11:18 AM
Powerstroke Techie
The one you should be getting is grey and only $30
Old 07-31-2007, 05:14 PM
I'll place my bet on the ICP sensor....
Tom
