1997 F250 7.3L motor problem.. need help - Ford Powerstroke Diesel Forum
Old 07-30-2007, 07:02 AM
I have a 1997 ford f250 7.3l powerstroke with a 5 speed manual trans. i am having trouble with the motor when it is cold. when i start the truck when the motor is cold, it will start up fine. but then when i get in it to drive down the road.. it acts like it has no power... like as if maybe an injector is not firing right. but as soon as the motor warms up to normal running temp, she runs like a bat out of hell. i did a diagnostics test on it and no codes came up... does any body know what might be the problem here and what i have to do to fix it...
thanks
dan
Old 07-30-2007, 07:09 AM
ADMIN AND TECH
injectors are sticking cold pinpoint which one or ones are skipping cold and replace them
Old 08-09-2007, 06:06 AM
How hard is it on the motor? when the motor is warm, it also has problems when i have it in first, when you stomp on the gas it doesnt want to go anywhere, it takes like approx. 8 seconds to get through first gear, then when i shift it into 2nd, sometimes its a little sluggish.
Old 08-09-2007, 06:26 AM
ADMIN AND TECH
its not really hard on the motor , just aggravating to you, you mean after its warm right
Old 08-09-2007, 07:55 AM
COLLEGE KID
Send a message via AIM to lifewitlooie
would runnning some injector cleaner fix that up for you?
Old 08-09-2007, 08:56 AM
ADMIN AND TECH
probably not , usually once they get to bad , the damage is already done
