My OASIS.... - Ford Powerstroke Diesel Forum
post #1 of 17 Old 07-29-2007, 05:57 PM Thread Starter
Strőkër~X's Avatar
Arrow My OASIS....
well here is my OASIS, i dont mind sharing the info, heck maybe you can enlighten me somewhat, as far as i can tell (NOOB) all looks minor,
LOL @ customers poor MPG comment.......
Standard Claims List For Model Year 2004
Detailed Vehicle Specification
VIN VEH LINE MKT DERIV BODY CAB VER SERIES DRIVE TYPE PLT CD TRS CD ENG CD PROD DATE WARR DATE SELLING DEALER SELL CNT TIS WCC CPSC_6 PREF BASE SUFF CCC CD DIST(Miles)
1FTNW21P94EC79906 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 09-MAR-2004 07-OCT-2004 153553 USA 0 6P07 010301 * 2820124 * R22 07 191
AWS Claim Key: 1392060 Trx Code: 1 Labor Hrs: 1.8
Dlr Cd-Sub Cd: 06031 - * Name: LACY MOTORS, INC. Ph: 620-2411042 St:KS Ctry Cd: USA Reg Cd: NA Repr Date:15-JUN-2004 Doc #:09704901
Cust Comments: WINDNOISE
Tech Comments: TEST DRIVE TO CONFIRM CUSTOMER COMPLAINT ADJ LH FRT AND REARDOORS AND HINGES TO FIT BODY ADJ LH FRT AND REAR STRIKERS ADJUST RH FRT DOOR ON HINGES AND STRIKER TEST DRIVE AGAIN TO CONFIRM REPAIRS
1FTNW21P94EC79906 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 09-MAR-2004 07-OCT-2004 153553 USA 5 1H03 030008 3C3Z 9F452 AC D50 42 5175
AWS Claim Key: 3717709 Trx Code: 1 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 06031 - * Name: LACY MOTORS, INC. Ph: 620-2411042 St:KS Ctry Cd: USA Reg Cd: NA Repr Date:08-FEB-2005 Doc #:00177901
Cust Comments: ENGINE IS BLOWING ALOT OF BLUE SMOKE
1FTNW21P94EC79906 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 09-MAR-2004 07-OCT-2004 153553 USA 5 2G05 031405 * RECAL * A85 04 5175
AWS Claim Key: 3717710 Trx Code: 1 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 06031 - * Name: LACY MOTORS, INC. Ph: 620-2411042 St:KS Ctry Cd: USA Reg Cd: NA Repr Date:08-FEB-2005 Doc #:00177902
Cust Comments: CHECK FOR POOR FUEL MPG
1FTNW21P94EC79906 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 09-MAR-2004 07-OCT-2004 153553 USA 12 3A03 * * * * * * 9663
AWS Claim Key: 7096261 Trx Code: 04B24 Labor Hrs: 6.4
Dlr Cd-Sub Cd: 05254 - * Name: LONG MCARTHUR, INC. Ph: 785-8232237 St:KS Ctry Cd: USA Reg Cd: NA Repr Date:27-SEP-2005 Doc #:30572603
Cust Comments: CSP 04B24 TRANSMISSION REVERSE PLANET REPLACEMENT
Tech Comments: R&I TRANS INSPECT & REPLACE REAR PLANET ONLY AS PROVIDED BY CSP 04B24
1FTNW21P94EC79906 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 09-MAR-2004 07-OCT-2004 153553 USA 12 2H01 * * * * * * 9663
AWS Claim Key: 7096260 Trx Code: 05B29 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 05254 - * Name: LONG MCARTHUR, INC. Ph: 785-8232237 St:KS Ctry Cd: USA Reg Cd: NA Repr Date:27-SEP-2005 Doc #:30572604
Cust Comments: CSP 05B29 CHARGE AIR COOLER DUCT REPLACEMENT
Tech Comments: REPLACE THE CAC DUCT & CLAMPS AS PROVIDED BY CSP 05B29
1FTNW21P94EC79906 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 09-MAR-2004 07-OCT-2004 153553 USA 12 * * * * * * * 9663
AWS Claim Key: 7096259 Trx Code: 05S34 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 05254 - * Name: LONG MCARTHUR, INC. Ph: 785-8232237 St:KS Ctry Cd: USA Reg Cd: NA Repr Date:27-SEP-2005 Doc #:30572605
Cust Comments: FSA 05S34 FUEL INJECTOR CONTROL MODULE WIRING HARNESS REPAIR
Tech Comments: INSPECT FICM WIRE HARNESS FOR PART NUMBER CHAFING INSTALL FICM REPAIR KIT & INSTALL ICP CONNECTOR KIT AS PER THE TECH
AWS Claim Key: 7096258 Trx Code: 05E15 Labor Hrs: 1.3
Dlr Cd-Sub Cd: 05254 - * Name: LONG MCARTHUR, INC. Ph: 785-8232237 St:KS Ctry Cd: USA Reg Cd: NA Repr Date:27-SEP-2005 Doc #:30572606
Cust Comments: VOLUNTARY EMNIISSION RECALL 05E15 EXHAUST PRESSURE SENSOR REPLACE OBD & PCM RECALIBRATIONS
Tech Comments: REPLACE EP SENSOR EP CONNECTOR & RECALIBRATE CONTROL MODULES AS PER THE TECHNICAL INSTRUCTIONS
AWS Claim Key: 7096257 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 05254 - * Name: LONG MCARTHUR, INC. Ph: 785-8232237 St:KS Ctry Cd: USA Reg Cd: NA Repr Date:27-SEP-2005 Doc #:30572607
Cust Comments: CUSTOMER ASSURANCE TEST DRIVE 6.0L
Tech Comments: PERFORM CUSTOMER ASSURANCE TEST DRIVE AS PER THE TECHNICAL INSTRUCTIONS AFTER PERFORM 05E15
1FTNW21P94EC79906 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 09-MAR-2004 07-OCT-2004 153553 USA 19 5O01 110201 2C3Z 3504 AARM H21 42 14424
AWS Claim Key: 9263907 Trx Code: E84 Labor Hrs: 1.4
Dlr Cd-Sub Cd: 06031 - * Name: LACY MOTORS, INC. Ph: 620-2411042 St:KS Ctry Cd: USA Reg Cd: NA Repr Date:11-APR-2006 Doc #:02330401
Cust Comments: CUSTOMER WAS DRIVING DOWN THE ROAD AND STEERING BECAME INOP
Tech Comments: INSPECTED FOR DAMAGE.FOUND STEERING GEAR LOWER SHAFT BROKEN.REPLACED STEERING GEAR ASSY.
1FTNW21P94EC79906 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 09-MAR-2004 07-OCT-2004 153553 USA 23 2H01 031202 5C3Z 6C640 AA P67 42 16731
AWS Claim Key: 10164826 Trx Code: E84 Labor Hrs: 0.9
Dlr Cd-Sub Cd: 05254 - * Name: LONG MCARTHUR, INC. Ph: 785-8232237 St:KS Ctry Cd: USA Reg Cd: NA Repr Date:10-AUG-2006 Doc #:32423401
Cust Comments: C S VEHICLE DOWN SHIFTS ALOT
Tech Comments: DOES NOT OPERATE PROPERLY ENGINE PERFORMANCE DIAG KOEO KOEO PASS KOEC P0299 KOER PASS TEST DRIVE NO PROBLEM FOUND W TRANS BUT INTERCOOLER HOSE OFF BLOWS OFF WHILE DRIVING R&R INTERCOOLER HOSE CLEAR CODE TEST DRIVE RETEST PASS
1FTNW21P94EC79906 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 09-MAR-2004 07-OCT-2004 153553 USA 23 6B07 010101 * 2501610 * C20 42 16731
AWS Claim Key: 10164825 Trx Code: E84 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 05254 - * Name: LONG MCARTHUR, INC. Ph: 785-8232237 St:KS Ctry Cd: USA Reg Cd: NA Repr Date:10-AUG-2006 Doc #:32423402
Cust Comments: AC CUTS OUT AND GETS HOT
Tech Comments: FAILED SEAL CK AC OK PLUG MISSING FROM HOLE IN FIREWALL ALLOWING HOT AIR IN INSTALL SEAL BUTYLE PATCH ON FIREWALL
1FTNW21P94EC79906 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 09-MAR-2004 07-OCT-2004 153553 USA 24 1H03 030804 4C3Z 9J460 A D42 42 20222
AWS Claim Key: 10230568 Trx Code: S07 Labor Hrs: 2.2
Dlr Cd-Sub Cd: 05254 - * Name: LONG MCARTHUR, INC. Ph: 785-8232237 St:KS Ctry Cd: USA Reg Cd: NA Repr Date:31-AUG-2006 Doc #:32553001
Cust Comments: VEHICLE BLOWS BLACK SMOKE
Tech Comments: DOES NOT OPERATE PROPERLY VERIFY ENGINE PERFORMANCE DIAG KOEO PASS KOEC P0401 P0478 P2262 KOER PASS INJ PASS CLEAR CODES TEST DRIVE 5 RECORDINGS MGP 22 25 PSI EBP ERRATIC R&R EBP SENSOR CLEAR CODES
1FTNW21P94EC79906 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 09-MAR-2004 07-OCT-2004 153553 USA 24 2H01 031202 5C3Z 6C640 AA N12 42 20222
AWS Claim Key: 10230567 Trx Code: E90 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 05254 - * Name: LONG MCARTHUR, INC. Ph: 785-8232237 St:KS Ctry Cd: USA Reg Cd: NA Repr Date:31-AUG-2006 Doc #:32553004
Cust Comments: THERE WAS A LOUD POP IN THE ENGINE
Tech Comments: DOES NOT OPERATE PROPERLY VERIFY HOT SIDE CAC HOSE OFF REPLACE HOT SIDE CAC HOSE
im still alive and kickin...find me on FB..."StrokerX1"
SOLD my truck, another Diesel within 2011
NOTE: if your on OK and need some PSD work done, i know a dealer tech who does the work....PM me!
Strőkër~X is offline
post #2 of 17 Old 07-29-2007, 06:00 PM
Don't mind me
westcoaststrokin's Avatar
Quoted: 3 Post(s)
If you want to see a bad oasis I will be more than happy to post mine.
Josh
04 F350 CC SB DRW IT HAS SOME STUFF
"Idiopathic, from the Latin meaning we're idiots cause we can't figure out what's causing it." House M.D.
westcoaststrokin is offline
post #3 of 17 Old 07-29-2007, 06:02 PM
FJuanfiddy mod
Dave's Avatar
Quoted: 10 Post(s)
Looks like some CAC boot tubes blew off and the reverse planetary recall was done
Email:
2006 F250 ECSB Lariat 4x4
Edge Insight CTS
Coolant filter
Dave is offline
post #4 of 17 Old 07-29-2007, 06:06 PM
That dude was blowing CAC tubes left and right.. hehe
how bad would this suck...
Blue01F250 is offline
post #5 of 17 Old 07-29-2007, 06:09 PM
Don't mind me
Quoted: 3 Post(s)
Here is mine.
1FTWW33P14EB71318 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 03-DEC-2003 24-DEC-2003 172412 USA 9 2E03 030402 * 9F593 * D11 X2 12731
AWS Claim Key: 1792835 Trx Code: S07 Labor Hrs: 2.7
Dlr Cd-Sub Cd: 07725 - * Name: SALINAS VALLEY FORD SALES Ph: 831-7584444 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:30-AUG-2004 Doc #:15451001
Cust Comments: CUST STATES WHEN COLD IT REVS UP OCCASIONALLY WHILE IDLING T O WARM UP, ALMOST SOUNDS LIKE A MISS(NOT TOUCHING ACCEL).
Tech Comments: DTC# P1000 INJECTOR WIRE HAD COME OFF RECONNECTED INJECTOR WIRE, CLEARED DTC CODES & TEST DROVE VE HICLE, OK.
1FTWW33P14EB71318 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 03-DEC-2003 24-DEC-2003 172412 USA 10 2G05 031405 * RECAL * D36 42 14548
AWS Claim Key: 2079441 Trx Code: E84 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 07725 - * Name: SALINAS VALLEY FORD SALES Ph: 831-7584444 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:27-SEP-2004 Doc #:15600101
Cust Comments: CUST STATES ENGINE SURGING & STUMBLES AT TAKE OFF. CHECK & A DVISE.
Tech Comments: RESET THE IGNITION MODULE AND TRUCK RUNS GOOD AT THIS TIME.
1FTWW33P14EB71318 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 03-DEC-2003 24-DEC-2003 172412 USA 10 2G05 031405 * RECAL * D36 42 15517
AWS Claim Key: 2189290 Trx Code: E84 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 07725 - * Name: SALINAS VALLEY FORD SALES Ph: 831-7584444 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:04-OCT-2004 Doc #:15643701
Cust Comments: CUST STATES VEH HAS SURGING WHEN TOWING AND AC IS ON, EVEN IF TOWN BUTTON IS ON AND AC BUT NOT TOWING CHECK AND ADVISE.
Tech Comments: REPROGRAMED PCM ALL O.K NOW. NO CODES IN SYS AFTER CHECKING
1FTWW33P14EB71318 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 03-DEC-2003 24-DEC-2003 172412 USA 10 2E06 030008 4C3Z 9C891 AB D36 42 15778
AWS Claim Key: 2821023 Trx Code: E84 Labor Hrs: 8.9
Dlr Cd-Sub Cd: 07725 - * Name: SALINAS VALLEY FORD SALES Ph: 831-7584444 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:11-OCT-2004 Doc #:15673001
Cust Comments: CUST STATES VEH HAS SURGING ON FREEWAY AND AT IDLE AFTER SITTING FOR 5 MIN AND LIGHTS ON WITH A.C VEH WANTS TO DIE.
Tech Comments: CHECKED OUT VEH PERFORMED FUSE SEPERATION PER FORD THEN ORDERED NEW UPDATED HARNESS. INSTALED NEW UPDATED COMPLETE ENGINE HARNESS.
1FTWW33P14EB71318 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 03-DEC-2003 24-DEC-2003 172412 USA 12 7K12 011202 3C3Z 10D898 AA A85 42 16752
AWS Claim Key: 3390233 Trx Code: E83 Labor Hrs: 2.5
Dlr Cd-Sub Cd: 07725 - * Name: SALINAS VALLEY FORD SALES Ph: 831-7584444 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:01-DEC-2004 Doc #:15933501
Cust Comments: CUST STATES VEH HAS TEMP READING INOPP (AMBIENT OUT)
Tech Comments: CHECKED OUT AMBIENT TEMP FOUND AMBIENT INOP REPLACED AMBIENT AND RESET IT ALL O.K NOW.
1FTWW33P14EB71318 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 03-DEC-2003 24-DEC-2003 172412 USA 12 7S14 1801XX * 13A709 * D21 42 16752
AWS Claim Key: 3390232 Trx Code: E83 Labor Hrs: 3.1
Dlr Cd-Sub Cd: 07725 - * Name: SALINAS VALLEY FORD SALES Ph: 831-7584444 St:CA Ctry Cd: USA Reg Cd: NA Repr Date:01-DEC-2004 Doc #:15933502
Cust Comments: CUST STATES VEH WILL DIE AT IDLE AFTER RUNNING FOR ABOUT 10 MIN ALSO WHEN DRIVING AFTER WARM CHECK AND ADVISE.
Tech Comments: CHECKED OUT VEH THE ENGINE HAD CODE FOR FCCM NO POWER REMOVED FUSE BOX AND CRIMP REPAIRED FUSE FITS SOLID NOW TEST DROVE ALL O.K NOW.
1FTWW33P14EB71318 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 03-DEC-2003 24-DEC-2003 172412 USA 19 6Y20 000079 * RAV * A98 82 20918
AWS Claim Key: 5996373 Trx Code: RAV Labor Hrs: 1
Dlr Cd-Sub Cd: 04842 - * Name: SUNNYVALE FORD Ph: *-* St:CA Ctry Cd: USA Reg Cd: NA Repr Date:30-JUN-2005 Doc #:51639601
Cust Comments: PERFORM RAV INSPECTION PER ATTACHED SHEET
Tech Comments: PERFORMED RAV INSPECTION
1FTWW33P14EB71318 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 03-DEC-2003 24-DEC-2003 172412 USA 19 6Y20 000001 * MISC * A98 82 20918
AWS Claim Key: 5996374 Trx Code: P86 Labor Hrs: 0
Dlr Cd-Sub Cd: 04842 - * Name: SUNNYVALE FORD Ph: *-* St:CA Ctry Cd: USA Reg Cd: NA Repr Date:30-JUN-2005 Doc #:51639602
Cust Comments: CUST STATES THAT THE VEHICLE STALLS & QUITS
Tech Comments: VERIFIED CONCERN FOUND THAT THE WIRE LOOM WAS THE CAUSE OF CONCERN. REPLACED UNDER RECALL 05S34
1FTWW33P14EB71318 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 03-DEC-2003 24-DEC-2003 172412 USA 19 2G05 031405 * RECAL * D50 04 20918
AWS Claim Key: 5996375 Trx Code: E84 Labor Hrs: 0.5
Dlr Cd-Sub Cd: 04842 - * Name: SUNNYVALE FORD Ph: *-* St:CA Ctry Cd: USA Reg Cd: NA Repr Date:30-JUN-2005 Doc #:51639603
Cust Comments: RECALIBRATE PCM TO THE LATEST CALIBRATION
Tech Comments: RECALIBRATED PCM TO THE LATEST CALIBRATION
1FTWW33P14EB71318 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 03-DEC-2003 24-DEC-2003 172412 USA 19 * * * * * * * 20918
AWS Claim Key: 5996376 Trx Code: 05S34 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 04842 - * Name: SUNNYVALE FORD Ph: *-* St:CA Ctry Cd: USA Reg Cd: NA Repr Date:30-JUN-2005 Doc #:51639604
Cust Comments: PERFOMR RECALL 05S34
Tech Comments: PERFORMED RECALL 05S34
Josh
post #6 of 17 Old 07-29-2007, 06:09 PM Thread Starter
Strőkër~X's Avatar
LMAO!!!!!!!!!!!!!!!!!!!!
post #7 of 17 Old 07-29-2007, 06:09 PM
Don't mind me
Quoted: 3 Post(s)
And here is the second half.
AWS Claim Key: 5996377 Trx Code: 05E15 Labor Hrs: 1
Dlr Cd-Sub Cd: 04842 - * Name: SUNNYVALE FORD Ph: *-* St:CA Ctry Cd: USA Reg Cd: NA Repr Date:30-JUN-2005 Doc #:51639605
Cust Comments: PERFPRM RECALL 05E15
Tech Comments: REPLACED EBP SENSOR AND CONNECTOR RECALIBRATED PCM AND TCM AND ICM PER 05E15
1FTWW33P14EB71318 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 03-DEC-2003 24-DEC-2003 172412 USA 19 7K12 011202 3C3Z 10D898 AA G32 42 20918
AWS Claim Key: 5996378 Trx Code: E83 Labor Hrs: 1.7
Dlr Cd-Sub Cd: 04842 - * Name: SUNNYVALE FORD Ph: *-* St:CA Ctry Cd: USA Reg Cd: NA Repr Date:30-JUN-2005 Doc #:51639606
Cust Comments: INSPECT OVER HEAD TRIP COMPUTER NO FUNCTIONING
Tech Comments: VERIFIED CUST CONCERN PERFORMED PIN POINT TEST FOUND MODULE NOT FUNCTIONING RECOM REPLACE REPLACED MODULE REINSTALLED OVER HEAD CONSOLE AND RECKD OK NO OPS IN SLTS CD ROM FOR COMPONENT
AWS Claim Key: 5996379 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 04842 - * Name: SUNNYVALE FORD Ph: *-* St:CA Ctry Cd: USA Reg Cd: NA Repr Date:30-JUN-2005 Doc #:51639607
Cust Comments: RECALL 59B01
Tech Comments: PERFORMED RECALL 59B01
1FTWW33P14EB71318 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 03-DEC-2003 24-DEC-2003 172412 USA 27 * * * * * * * 20983
AWS Claim Key: 8543235 Trx Code: 05E16 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 08646 - * Name: BAY FORD Ph: 360-8764484 St:WA Ctry Cd: USA Reg Cd: NA Repr Date:14-FEB-2006 Doc #:109341A
Cust Comments: PERFORM EMISSION RECALL 05E16
Tech Comments: REPROGRAMMED PCM
1FTWW33P14EB71318 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 03-DEC-2003 24-DEC-2003 172412 USA 27 1H03 030008 * 9F452 * E29 69 20983
AWS Claim Key: 8645065 Trx Code: S07 Labor Hrs: 2.1
Dlr Cd-Sub Cd: 08646 - * Name: BAY FORD Ph: 360-8764484 St:WA Ctry Cd: USA Reg Cd: NA Repr Date:16-FEB-2006 Doc #:109443A
Cust Comments: CHECK AND ADVISE ON NOISE KEY ON,BEFORE CRANKING ENGINE AND ENGINE LAMP IS ON
Tech Comments: INSPECTED TEST, PO299 PERFORMED SHEET 1 THRU 8 EGR AVLEV STUCK REPLACED EGR RETESTE CLEARED CO DES, PI408 INT SICKY VGT CLERED CODES AND ROAD TESTED ALL OK.
1FTWW33P14EB71318 T/F7 F T/BC T/CD T/E A1 T/BE T/YB 03-DEC-2003 24-DEC-2003 172412 USA 29 2H01 030008 4C3Z 6K682 BA D42 69 21052
AWS Claim Key: 9376583 Trx Code: S07 Labor Hrs: 5.8
Dlr Cd-Sub Cd: 08646 - * Name: BAY FORD Ph: 360-8764484 St:WA Ctry Cd: USA Reg Cd: NA Repr Date:28-APR-2006 Doc #:111516A
Cust Comments: CHECK AND ADVISE ON TEST DRIVE VEHICLE HAD NO TURBO BOOST,LACKS POWER AND MAKES NOISE FROM ENGINE
Tech Comments: PERFORMED DIESEL DIAGNOSIS,ROADTEST FOUND SLOW AND COUGHS,PERFORMANCE SHEET TESTS,P0299 IN SYS TEM,PERFORMED PINPOINT TESTS,FOUND TURBO STICKI NG,REMOVED TURBO,DEGAS BOTTLE,CAC TUBES,AIR INT AKE FOR ACCESS,M TIME TO REMOVE ROUNDED TURBO B OLT,REASSEMBLED AND RETEST ALL OK
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2004 F-SERIES BODY STYLE
F-350 CREW CAB 4X4 ENGINE
6.0L DIESEL DI V8
TRANSMISSION
TORQSHIFT AXLE CODE
F2 ENGINE CALIBRATION
4F710N0A
WARNING MESSAGES
CUDL - THIS VEHICLE HAS A CLOSED CUDL CONTACT
OTHER WTYS MAY APPLY/REACQUIRED VEH WTY EXP 07-11-2007 DISTANCE 33773
VERIFY STATE REGISTRATION, VIN MAY BE ELIGIBLE FOR CALIFORNIA
EMISSIONS WTY
ARN MESSAGES
ATTENTION TECHNICIANS AND SERVICE MANAGERS:
BEFORE REPLACING FUEL INJECTORS FOR COLD ENGINE OPERATION SEE TSB
07-05-04
BEFORE REPLACING 6.0L EGR VALVE REFER TO 06-19-06
BEFORE REPLACING 6.0L TURBOCHARGER OR VGT SOLENOID REFER TO 06-23-02
GENERAL WARRANTY INFORMATION
WARRANTY START DATE
12/24/2003
BUILD DATE
12/03/2003
SALE MILEAGE
00008
OUTSTANDING FIELD SERVICE ACTIONS
NO CAMPAIGN MESSAGE(S) FOUND
EXTENDED COVERAGES
0701 - USA 2006 NEW 84/75,000 PREMIUMCARE W/ROADSIDE
STANDARD DEDUCTIBLE: 100 USD
OWNER NAME: JOSHUA HARSHMAN
OPTIONS:
EXPIRATION DATE: 12/24/2010
DISTANCE: 75,000
RENTAL: 28 UP TO 10 DAYS
TOWING: 0 USD
CONTRACT SOLD BY: USA 08646
ESP CONTRACT START DATE: 12/24/2003
WARRANTY REPAIR HISTORY
04/28/2006
DEALER: Bay Ford
WARRANTY CLAIM NUMBER: 111516 ODOMETER: 021052M
PART NUMBER PART DESCRIPTION QUANTITY
LABOR OP
CONDITION CODE
CONDITION DESC
4C3Z 6K682BA TURBO CHG-EXH DRIVE 001 6005F 69 FROZEN/SEIZED/BINDING
VC 7B
STICKI NG,REM OVED TURBO,DEGAS BOTTLE,CAC TUBES,AIR INT AKE FOR
ACCESS,M-TIME TO REMOVE R OUNDED TURBO B OLT,REASSEMBLED AND RETEST ALL OK
Josh
post #8 of 17 Old 07-29-2007, 06:13 PM
yah... im not gonna read all that
post #9 of 17 Old 07-29-2007, 06:19 PM
Don't mind me
Quoted: 3 Post(s)
Yeah that kinda hurt after I found this site. But she has ran like a Champ since I have owned her.
Josh
post #10 of 17 Old 07-29-2007, 06:19 PM
at least you all know what was done to your truck... look at mine...
VEHICLE INFORMATION
VEHICLE DESCRIPTION
2001 F-SERIES BODY STYLE
F-250 CREW CAB 4X2 ENGINE
7.3L TURBO - DI
TRANSMISSION
4R100 4SP (DIESEL) AXLE CODE
ENGINE CALIBRATION
1F719S0A
NO WARNING MESSAGES FOUND FOR THIS VIN
ARN MESSAGES
BEFORE REPLACING DIESEL HIGH PRESSURE PUMP (-9A543-) SEE TSB 04-04-04
WARRANTY START DATE
04/04/2001
BUILD DATE
03/25/2001
SALE MILEAGE
00100
EXTENDED COVERAGES
NO ESP INFORMATION AVAILABLE
NO RECENT REPAIR HISTORY ON VEHICLE
