SOMEONE PLEASE HELP! 2004 6.0 - Ford Powerstroke Diesel Forum
Old 04-14-2011, 05:28 AM
I am ready to lose it.
Try to make this as short as possible.
I just attempted to remove the Western Pro Plow Ultra Mount frame, controls and wiring.
I was able to remove everything without much problem.
HOWEVER, I now have no headlights, the headlights plug into an isolation module which is to differentiate between the plow lights and the headlights when plow is on or off. Supposedly, the plugs just pull out of the isolation module and back into the factory harness. Problem is, I cannot find a picture, ANYWHERE, of where the headlights plug into. I didn't install the plow so I don't know if the headlight harness was changed but I did call the plow manufacturer and they told me that the installation is plug and play so I am assuming that the headlight wire harness plugs back into the OEM, but where.
I took out my battery, air cleaner and can trace the wires from the head lights, but cannot find where they plug in. I also looked under my dash in case they plug in somewhere under there but I can't find any empty male plugs. The plugs on the end of the headlight wire harness are 10 or 11 pin female with all different color wires.
I spent about 3 hours tryuing to find an picture or illustration on the internet but there is nothing, anywhere.
Does anyone have any idea?
Thanks.
