problems while backing up - Ford Powerstroke Diesel Forum
Old 07-25-2007, 12:01 PM
i have a 1997 f250 crew cab. it has a 10 inch lift with 37 inch toyos. it also has IFS. when i go in reverse and start backing up the top of my front wheels lean in towards the engine real bad. as soon as i put it in drive and start going they straighten back out. what is this?
Old 07-25-2007, 12:06 PM
Sounds like ball joints get in the truck and turn the wheel all the way in one direction then get out if one is leaning alot more that the other,(ball joints)
Old 07-25-2007, 12:08 PM
you can also jack it up and grab the top and the bottom of the wheel and try to move it in and out top to bottom if so (ball joints)
Old 07-25-2007, 12:18 PM
International Threat
Ball joints, wheel bearings, and just the fact that you have the TwinTraction I beam suspension can lead to this. Use DJjordan's ideas to determine where your trucks structure is moving when it shouldn't be!
Old 07-25-2007, 01:02 PM
ADMIN AND TECH
the twin i beam suspension on that truck is supposed to do that , with it lifted it will exxagerate it, that is normal, do not replace any parts
Old 07-25-2007, 03:50 PM
word. thanks
Old 07-25-2007, 03:53 PM
COLLEGE KID
Send a message via AIM to lifewitlooie
just dont go in reverse. ever
Old 07-26-2007, 12:52 AM
i disagree,replace the ifs with a solid axle immediately
Old 07-26-2007, 01:56 AM
i got the same problem.. searching really helps!!
Old 07-26-2007, 02:22 AM
COLLEGE KID
solid axle sounds good.. i was kidding about goin in reverse lol duh! its fine.. dont werry about it
