Stcks with tonneau cover? - Ford Powerstroke Diesel Forum
Old 07-22-2007, 09:07 AM
Anyone know if anybody has stacks with a tonneau cover? I am looking to get stacks but have things in the back of my truck that cannot get wet so i would like to leave my cover on. has anyone had this same problem?
Old 07-22-2007, 09:48 AM
Definitely wouldn't keep things dry. Can't think of any way to keep it all sealed up. Maybe someone else will have some ideas?
Old 07-22-2007, 09:51 AM
M4 in my tool box
I am having the same issue. I already have my stacks so when i install, I will let you know what i figure out. I have seen a few with stacks and covers but dont know for sure how it was done or how dry things stay.
Old 07-22-2007, 09:52 AM
Fiberglass or vinyl type covers?
Old 07-22-2007, 09:58 AM
i have a vinyl cover. i could possibly get a fiberglass, but just trying to make up my mind on exhaust and if i got stacks how to seal the bed up.
Old 07-22-2007, 10:00 AM
Send a message via AIM to oafydude28 Send a message via Yahoo to oafydude28
I would think if you had a soft cover that you could cut out the space you needed and then you would have to fabricate some round rubber gaskets. that should seal the bed from water intrusion as long as it was a tight seal around the staks. As for a fiberglass cover i dont think you could make it work and still look good. just a thought.
M4 in my tool box
mine is a vinyl, but i have seen them poke up through both.
Old 07-22-2007, 10:02 AM
M4 in my tool box
where would a guy find High temp round rubber gaskets in 7" and how would you attach them to the cover?
Old 07-22-2007, 10:03 AM
That is what i was thinking with the rubber gasket. Yet i was going to ask if the rubber gasket would melt, or would the cover burn up if it is on the exhaust.
Old 07-22-2007, 10:11 AM
M4 in my tool box
yeah, that is the thing i dont know. if it wouldnt burn up i would just cut the hole a lil bit small and stuff the satck down through it and that should keep most the water out. you think
