7.3 Flywheel and clutch assembly - Ford Powerstroke Diesel Forum
post #1 of 4 Old 05-16-2006, 07:07 PM Thread Starter
Anyone know how to tell if its a solid or dual mass flywheel without tearing it all apart? 1997 F-350 7.3 Powerstroke 5 Speed
matt_71 is offline
post #2 of 4 Old 05-16-2006, 07:14 PM
unless its been messed with prior to you, it should be a standard, solid flywheel....but you cant really tell without disassembling it.......Marc
mschn99 is offline
post #3 of 4 Old 05-22-2006, 02:40 PM
gonecheenin's Avatar
My 97' has the factory dual mass clutch
i can tell because it rattles and shudders cleary indicating its ready to come apart
still trying to decide what kind of clutch to buy (LUK or South bend, cerametallic or ETC) so that when i add the HP injestors and chip i don't end up with a slipping clutch
97' F-250 HD XL
Ext. Cab, 8 foot bed, 5 speed, 4x4, added cruise control
-285x75 R16 Maxxis E rated MA761 Bravo's
(soon to be on 16x10 Eagle alloys)
-LUK Gold series solid flywheel kit
-DIY intake
-MBRP 3" downpipe to 4" exhaust with open muffler & cat delete
-EGT, Boost, & Fuel pressure on A-pillar in factory styling
-Baby Swamps injectors
-Custom burnt (J. Tipton)2 position chip
6000lb's of pure adrenaline
Tearin' it up @
gonecheenin is offline
post #4 of 4 Old 06-03-2006, 01:45 PM
Radio Flyer's Avatar
A stock '97 will have a dual mass flywheel.
If you pull the inspection cover off and look up in there you can usually tell. The solid conversion flywheel is slightly thinner---the factory dual mass is pretty thck. If the truck has more than 50,000 miles on it you should be able to get a little bit of movement out of the DMF by prying on the ring gear with a flywheel turning tool, or big screwdriver.
Hope this helps,
Dan-
1997 F350 reg cab 4x4 5spd 4.10LSD
Radio Flyer is offline
