Rear Differential question
My old 94' F-250 has a limited slip rear end. It is fantastic for plowing. I am not convinced yet that my new 99 F-350 is the same. I have not driven it enough to be certain. Does anyone know, if it turns out to be a regular differential, if I can convert it over to a limited slip with just a gear change or do I have to replace the entire unit.
Thanks |
If I'm wrong on this, pretend I was never here! Someone smarter will chime in shortly.
if you have the money, put a detroit true trac in it
To change it over to limited slip you need to swap the center carrier for one that has the clutch packs in it.
I would opt for the ARB air locker or the Eaton E locker over the Detroit locker. That would allow you to turn it on an off as needed. Detroit's can be a bit of a nuisance on the street. Of course a clutch bases system like Ford's will be cheaper but doesn't lock up very well IMO.
The ARB and EATON lockers are NICE but they are exspensive . I would find a factory possi ford carrier . I think they are called trac loc
I noticed in the snow that both spin fairly easily. But on dry tar I was getting into traffic and nailed it to get out of the way and I spun out on 1 tire for a while. So I am still uncertain if I have posi.
One wheel peel doesn't mean it's not a posi , could have worn cluch pack . Is there a tag on the rear end ? Otherwise pull the cover ant take a peek
Ok thanks I will check. umm er what would the tag say - "posi"??
And if I were to open it up (which I need to do to change the oil) what am I looking for to indicate it a posi? |
Well my dana80 says ls . Don't know about the Sterlings . Well it will have the have clutch packs , I can't remember if you can see them without pulling the center section now that I think of it . If I remember correctly , if it's a posi . if you spin the passenger tire forward the drivers tire will turn forward as well , an open rear end the drivers tire will spin backwards .
