too much fuel ? - Ford Powerstroke Diesel Forum
post #1 of 13 Old 07-11-2007, 04:07 PM Thread Starter
powershooter's Avatar
Send a message via AIM to powershooter
Exclamation too much fuel ?
so today i fueled up and i put as much fuel in it as possible like i read on hear, so i would get the most in my tank. i noticed fuel dripping down the side of the tank comming from the top of the tank , wtf ! did i put to much fuel in it ? so , i called the dealer and they said to drive it to lower the fuel level and bring it in and they would be glad to check it out . has anybody ever had this happen before ? this is the first time that i ever had this happen .
thanks , powershooter .
06 F250 SD, Extended cab, Short Bed, Arizona Biege,
6.0l, ZF6 Manual trans, Bone Stock Motor, Zooo Daaad
CB and custom stainless steel CB mount .
Custom antenna mount
Custom built front hitch ( 3 recievers )
Future mods
Custom built bars for the front and rear , all removable .
Custom built headache rack and bed rail .Anything else i can build myself because it is FREE !
powershooter is offline
post #2 of 13 Old 07-11-2007, 04:21 PM
SgtStroked7.3's Avatar
Send a message via Yahoo to SgtStroked7.3
you filled it all the way up? yeah its gonna leak out of the filler neck especially when u drive and its sloshing around in there. I dont think u have much to worry about.
2001 F250 SuperDuty 7.3
AutoMeter Gauges, 5" Turbo Back Exhaust, aFe Stage II Intake, XCal 2 With Tadds Tunes,
2" Leveling Lift, Custom Built Transmission, AIH Boost Fitting.
Snow Performance Water/Methanol Injection Coming Soon...
"When the rich wage war, It's the poor that die"
-Unknown
SgtStroked7.3 is offline
post #3 of 13 Old 07-11-2007, 04:24 PM
You got it easier than me. I was filling up with a high flow pump and about 5 seconds into filling it burped threw the nozzle out and soaked me in diesel.
2005F250 is offline
post #4 of 13 Old 07-11-2007, 04:42 PM
Jon
Guest
Posts: n/a
Quoted: Post(s)
Yeah
Its probably leaking out the sending unit gasket. Its a big no no to fill these things past where there supposed to be. Just cuz you can get 31 gallons in a 29 gallon tank doesnt meen the factory screwed up. There specs are on USABLE space in the tank. It has to beable to expand and contract. I run my truck down to E and put about 25 gallons in it. Its a 29 gallon tank.
post #5 of 13 Old 07-11-2007, 04:59 PM
Treeman587's Avatar
Yeah you just put too much in it.
When I use the Big Rig pumps I put the handle on the slow click so it doesnt foam up as bad and burp, etc.
2005 F250 CC 4X4 Lariat
Alpine in dash DVD
MBRP Turbo Back 4"
Zoodad
Airaid
SCT
Some Guages
Rize Ind 6" with 18x12's and 35" MTZ's
Treeman587 is offline
post #6 of 13 Old 07-11-2007, 05:28 PM Thread Starter
yeah i figured that , but i will still let the dealer check it out just to be safe since it is under warrenty. even if they wont cover it i am still letting them check it out . i dont mind paying , just want everything to be correct and safe.
Future mods
post #7 of 13 Old 07-11-2007, 05:39 PM
I fill mine up all the way to the brim and it doesn't leak..... course that is usually when I am going to be drive 100 miles back home - so it gets used up and the level drops w/i an hour or so
Blue01F250 is offline
post #8 of 13 Old 07-11-2007, 05:48 PM Thread Starter
all of this happened when i was finishing fueling and before i put the cap on.
Future mods
post #9 of 13 Old 07-11-2007, 07:43 PM
lilredpowerstroke's Avatar
I fill both of mine up till I cant put anymore in the tank and have never had a leak before.
T.J.
2003 F-350 dually 6.0
Centennial Edition
Straight exhaust 34x10.50 Swampers on Black Rock Stars
Been a member longer than most of the moderators
Thats why I said most Tiff
Think you can trust the government? Ask an American Indian!
My old truck in action
lilredpowerstroke is offline
post #10 of 13 Old 07-17-2007, 05:41 PM Thread Starter
got a call from the dealer today , it was a bad gasket on top the fuel cell . its covered by the warrenty and good to go. i must have put enough fuel in it to see it leak they said .
Future mods
