Need some help 6.0 liter PLEASE
I am looking at buying a 6.0 and I've heard all the horror stories about them, so I am looking at some input/opinions on a potential purchase. I'm looking at picking up the truck this Sat. and the drive will be 12 hrs round trip. Here is some info, it is a 2006 with 79k miles, FX4, Lariat, 4" lift, 35x12.5x20, and looks to be in real good shape. As soon as I purchase the truck I will be putting a Ford Extra Care Plus powerstroke warranty on the truck since the factory warranty will be out in April 2011. I had a buddy run an oasis report on the truck and the only warranty work that has been done on the truck was a fan clutch, driver's seat heater, #6 & # 7 injectors, EGR, valve cover gaskets, valve cover dummy plugs replaced, everything else was just usual maintenance stuff. Please let me know if this might be one of the "good ones", I'm just concered everybody keeps mentioning the Dodges over the F250s. The truck will mainly be used for daily driving and pulling a 23ft boat.
Thanks Dustin |
With the EGR being done under warranty, I'd ask to know more about what was done. Replacement of the Cooler, or the valve? If it was the cooler, see if the oil cooler was taken care of as well (The oil cooler is the reason these EGR coolers fail in the 6.0). Ask about if the gaskets where checked for being blown in regards to the EGR cooler.
I know this seams like a lot to look at. And I'm not saying its a no-sale condition, if you turn something up. The 6.0 has the power and reliability to make a great truck, you just need to know what you're getting into. |
Each shop may be different. I just had the EGR cooler rupture, my gaskets let go on me last month. It was due to the Oil Cooler, and both were replaced along with head gaskets. With yours being done that soon, the oil cooler probably wasn't looked at.
So would the oil cooler be something that should be replaces ASAP if I buy the truck? |
ASAP, maybe, and maybe not. If you can get a hold of an Edge Insight, or similar device, or have a dealership check your EOT/ECT you can make that decision. A difference of 15* between the two is a sign that cooler's is plugging up. If you come near that number, then yes I would say change it. While you're in there for that do something (upgrade / delete) to your EGR cooler. Both should always be done at the same time, due to their unique relationship in causing issues with the 6.0. At least till you get the orginal EGR cooler out of there.
So does it sound like a pretty solid truck??
