Isn't there an adapter for the fuel filter plug on the frame of the truck? - Ford Powerstroke Diesel Forum
post #1 of 4 Old 01-31-2011, 09:17 AM Thread Starter
philbio2k's Avatar
I thought I read somewhere there is an adapter that will fit where the plug is on the fuel filter on the frame under the truck that allows you to open a valve and drain the water rather than removing the plug and the adapter is longer so you don't end up bathing in diesel fuel. Anyone have any info on this?
philbio2k is offline
post #2 of 4 Old 01-31-2011, 01:37 PM
RRF985's Avatar
Here is what you need:
Diesel Technician Society
2013 Ford Fusion Titanium AWD, Deep Impact Blue
Totaled 12-26-12 It will be missed.
2006 F-250SD Lariat CCSB Dark Stone
-ARP head studs
-SCT SF3 w/ SRL+
-BPD Semi-bullet proof kit
-BPD FICM
-High Idle
-Edge Insight CS w/ EGT
-GlowShift Fuel Pressure gauge
-285/70/17 Toyo Open-Country A/T
-4" MBRP Turbo-back w/ cat-delete
-Randy Ellis bar w/ Hella 500s
RRF985 is offline
post #3 of 4 Old 01-31-2011, 04:45 PM
I've been meaning to get one of those for a long time now. Need to do it. Cheap mod, and much easier to change filters I've heard.
2004 F250 CC SB 4x4 Lariat
WIX intake with zoodad mod
(05 & up) Innovative Diesel intake elbow with butterfly valve manifold removed
4" SS T-Back no kitty exhaust
SCT X3 w/ I.D. Custom Tunes
Gauges: EGT, Boost, Tranny Temp
Pace Edwards bed cover / B&W Gooseneck Hitch / Linex
DieselSite coolant filtration system
DC Power Engineering 250A Alternator
Submariners do it deeper!!!
ShawnCT450R is offline
post #4 of 4 Old 02-01-2011, 10:36 AM Thread Starter
philbio2k's Avatar
Ok Thank you very much. Believe it or not I did search this forum before I posted. Im going to order one today because I frequently have to open this plug to let the water drain out so the message "Water in Fuel" will stop coming up. Again thank you.
