2005 F250 6.0 HELP PLEASE - Ford Powerstroke Diesel Forum
post #1 of 4 Old 01-30-2011, 06:45 AM Thread Starter
I just purchased a 2005 F250 with 68000 miles it was serviced and went through ye Ford service dept 67 point check and given a clean bill of health. ( greeat condition). So it has been driven about 200 miles since then. today I drove down the street parked left it idel while I talke dwith a friend for about 10 minutes. Got back in the truck and put it in gear only to discover when I pushed the gasit did not respond. I was able to motor back down the street at idle speed. I tried all gears even reverse but to no avail. The throttle will not respond. I parked in the driveway and turned it off. Now it will not start. Please help and tell me waht to do. Stranded on a Sunday. Thanks
spannsan is offline
post #2 of 4 Old 01-30-2011, 07:55 AM
hmmm TPS bad?
Dietoremain is offline
post #3 of 4 Old 01-30-2011, 07:59 AM
Powerstroke Techie
forddieseldoctor's Avatar
Originally Posted by Dietoremain View Post
hmmm TPS bad?
More than likely not. Do you have a code reader or a scanner? You need to see what codes are in it, and if there is no codes then you need to be able to monitor icp, ficm voltage, and egr valve position.
Ford Senior Master Diesel Tech
IF YOU DON'T WANNA STAND BEHIND OUR TROOPS
THEN FEEL FREE TO STAND IN FRONT OF THEM
Meet Double Aught
2000 F250
forddieseldoctor is offline
post #4 of 4 Old 01-30-2011, 06:42 PM Thread Starter
up and running
Thanks for the advise however I changed the filters and it started right up and is running strong. I got lucky on this one...... Mahalo
spannsan is offline
