Go Back   Ford Powerstroke Diesel Forum > General Topics > General Diesel Discussion
Old 10-02-2005, 02:24 PM
sbarber sbarber is offline
New to the Powerstroke Diesel
I am looking at buying a 1997 F250 4x4 crew cab with a 7.3 powerstroke with 178,000 miles. The owner has a exhaust brake and a 5th wheel hitch he just put a new trasmission in it. My guess is he has been pulling heavy trailers. I don't know anything about diesel engines. Can anyone tell me what to look for so I do not buy a truck that needs a lot of repairs. Thanks Steve
Old 10-02-2005, 04:03 PM
jwiger jwiger is offline
Military Member
Send a message via ICQ to jwiger Send a message via AIM to jwiger Send a message via MSN to jwiger Send a message via Yahoo to jwiger
look for obvious leaks, and blue/gray smoke out the exhaust. The biggest thing with diesels is oil pressure/quality. these engines are built heavy and run low rpm's. which means as long as they have have good pressure and don't burn oil ( a sign of cylinder wall/piston ring wear, valve steam/seal wear, oil bad turbo bearings.
One thing i recomend doing is pulling the turbo intake hose the (largest pipe coming from the air cleaner) off and spin the turbo by hand, it should spin easy, and have only a slight side to side play if any.
If it's the original turbo and it's in good shape then chances are the rest of the engine is too.
Old 10-06-2005, 06:30 PM
Thanks James
Can I move the turbo fam with my finger?? Steve Thanks Again
Old 10-06-2005, 06:32 PM
Military Member
yes the Compressor wheel should move when you turn it, and it should be smooth too.
