2WD verses 4WD - Ford Powerstroke Diesel Forum
post #1 of 33 Old 07-10-2007, 07:34 AM Thread Starter
2WD verses 4WD
As I have been searching for my truck, I have come across another dilemma. I was wondering what the advantages and disadvantages of having 4WD over 2WD is? I will be towing a 7x16 enclosed trailer, loaded to the max limit of approx. 7000lbs. It very rarely snows in this neck of the woods and I don't do any off-road driving. So can someone help me determine if I need a 4WD or 2WD truck.
rondee is offline
post #2 of 33 Old 07-10-2007, 07:42 AM
Let's Run'em
TwinTurboStroker's Avatar
Quoted: 10 Post(s)
Well there are many ways to look at this dilemma of yours....if money is not really a factor and you like to sit high then I would lean to a 4x4. If gas is an issue and your looking for best mileage and the truck will NEVER see off-road, then I go the 2wd route. Personally I would pick a 4x4 just because of the traction advantage. I like to race the truck, haul things on and off road, and how it sits. If none of these are really a concern for you then I would save the money and go 2wd and put the money toward making the truck your own. Really I would rather have a 4x4 and not need it then need a 4x4 and not have it, also 4x4's resale for more....just my
-Julian
4th 6.fo
TwinTurboStroker is offline
post #3 of 33 Old 07-10-2007, 07:45 AM
rednek01's Avatar
Send a message via AIM to rednek01 Send a message via Yahoo to rednek01
I had this same delima and ended up getting the 4WD and dont regret it at all. I actually feel like if I had gotten a 2WD I would be dissapointed. Its nice to sit a bit higher in traffic and I have already used the 4WD on several occasions where I never thought I would. If you have 4WD you will end up using it whether its to gain traction in a race or to pull a friend out or like I did to pull some trees down out of a neighbors yard Get the 4WD if you can you wont regret it!
Michael
Aim/Yahoo: rednekcowboi01
FORD Makes it INTERNATIONAL Shakes it!
2004 CC 6.0 4x4 lariat
MODS:SCT XCAL3, Stacks!, Dfuser coolant filter, 6k HID's, High idle, CCV, Ranch Hand, homefabbed straight pipe, Zoo-dad, 2008 tailights, Isspro Boost gauge, Kenwood head unit, 2 mtx 10's and amp...
FUTURE MODS: Isspro trans EGT and volt gauges, ARP head studs, ???
Parts replaced so far: Oil cooler X2
, EGR cooler, ...no more please!
rednek01 is offline
post #4 of 33 Old 07-10-2007, 07:46 AM
cj41foley's Avatar
I have to say that driving right I've gotten 22 mpg out of my 2wd on the interstae with the sruise set at 72MPH, but I do miss not being able to click over into 4wd when I need it, but I rarely ever need it
Jason
2006 F250 2wd 6.0 psd, 8.96 1/8th mile with canned SCT tunes, now running Spartan Hybrid Race tune! AFE Stage 2 PRO DRY S, 4" turbo back str8 pipe in front of rear tire, auto, crew cab short bed, ZOO DAD mod, 5% tint over the factory tint.
Track Times!
Reaction---.674
60 ft-------1.892
594 ft------8.370
1/8th ET---8.965
1/8th MPH--75.63
cj41foley is offline
post #5 of 33 Old 07-10-2007, 07:50 AM
ADMIN AND TECH
SCUFFY828's Avatar
if youve ever driven a 2wd dually they wil get stuck in wet grass ,ive had two over the years and wouldnt get another one
ITS STOCK
SCUFFY828 is offline
post #6 of 33 Old 07-10-2007, 07:51 AM
Strokin' In Dixie-Land
Big AL's Avatar
If you can afford it, the 4WD comes in might handy. Again, you never know when you might need it. The way I see it, is if you have a PSD, you sure don't want to be seen stuck in a small mud-hole
:burnout :burnout :burnout
2005 XLT 4x4 Crew Cab 6.0. Torqshift Auto. Arizona Beige.
Mods - 4" FBD Turbo-Back Exhaust with Free-flow Muffler. Power Intake Elbow from Dfuser. Bug Shield. Vent Shades. Aries Step Bars. Custom heavy-duty floor mats. High Idle Mod (great!).
Big AL is offline
post #7 of 33 Old 07-10-2007, 07:53 AM
Heat's Avatar
Generally the only time mine goes offroad is when we go hunting... Even then a 2wd would generally suffice but going down washboard forest roads at 35 mph without 4wd would be downright scarry .... Of course getting back into some of the areas that we hunt would be a "no go" without 4wd....
I'll tell you what though, when we have our monsoon storms here in Arizona I could care less knowing that I have 4wd at the flick of a switch ...
Ken....
"It has been said that politics is the second oldest profession; I have
learned that it bears a striking resemblance to the first."
- Ronald Reagan
'06 F250 CC Lariat FX4 PSD, bone stock
Heat is offline
post #8 of 33 Old 07-10-2007, 08:18 AM
Treeman587's Avatar
If you have a 4X4 you can put big azz tires on it and exhaust. Then when you go out you can stomp the pedal and have your truck do all the whistlin for you.
2005 F250 CC 4X4 Lariat
Alpine in dash DVD
MBRP Turbo Back 4"
Zoodad
Airaid
SCT
Some Guages
Rize Ind 6" with 18x12's and 35" MTZ's
Treeman587 is offline
post #9 of 33 Old 07-10-2007, 08:50 AM
chairman123's Avatar
I vote 4x4 for the reason that if you ever need to move that trailer on grass or gravel you might need it.
2002 F250 Crew cab, short bed, Lariat, 2wd
7.3liter diesel, Automatic
[URL="http://cobbsdieselperformance.com"]
[/UR
79,000 miles
chairman123 is offline
post #10 of 33 Old 07-10-2007, 09:10 AM
duct tape & zip ties
bigcountrysg's Avatar
Ok mpg, hmmm my truck 4x4 gets around 20-21 mpg in two wheel drive. When I am in 4wheel drive I get around 18 mpg. So mileage should not be a concern. 4x4 is not just for when it is snowing outside. But what if you take a vacation to lets say my house in the dead of winter. Your going to be hating life in a 2wheeldrive truck.
Trust me spend the extra dough for the four wheel peel.
Your Actions Today, Decide Your Future Tomorrow
2005 6.0 Crew Cab Long Box Lariat, current truck
2004 6.0 destroyed by contaminated fuel
2002 7.3L burnt
bigcountrysg is offline
