Pros and Cons of 7.3? - Ford Powerstroke Diesel Forum
post #1 of 7 Old 01-25-2011, 07:39 AM Thread Starter
bigbird189's Avatar
Smile Pros and Cons of 7.3?
I am in the market for a Powerstroke. I have had a 2004 F-250 with a 6.0 powerstroke motor. I sold that a while ago because I was worried about all the issues they have. I was wondering if anyone could tell me the Pros and Cons of the 7.3. I know its a better motor but I want to know what kind of issues are common with it? I am thinking about buying a 99 F-250 powerstroke. What are the recalls on it other the famous GPR.
bigbird189 is offline
post #2 of 7 Old 01-25-2011, 07:44 AM
captinbill2003's Avatar
I dont know if I would have sold your 6.0. Its probably going to cost you more money to get into a 7.3, fix any issues with it, and set up the way you want it, rather then fix anything that MAY have happened to your 6.0. Lots of guys prefer the 1999-2000 (and certian ESN 2001's) because they had forged connecting rods versus the majority of 01's and all 02-03's. Read through the forums though, 7.3's have certian oil leaks common as well as compressor surge, rattling doors on ext cabs, pinion seal leaks, transmission problems here and there, deadhead fuel rails, ect.
2003 F250 Lariat 4x4 7.3L
8.5" Procomp Lift
38"x15.5"x16" Mickey Thompson Baja MTZ
SCT SF3 (DP Tunes in the works)
143,000 miles
Honest 14mpg city/16-17mpg hwy
captinbill2003 is offline
post #3 of 7 Old 01-25-2011, 09:59 AM Thread Starter
bigbird189's Avatar
Thanks for the info. I can say as for the 6.0 with mine, I had nothing but problems with it. Injectors, fuel Mang. Comp. plugs, trans, etc.. have all gone bad. I bought the truck brand new and if it weren't for the Extended warranty I would have to fork out of my own pocket at least $12,000 for all the things I have replaced. The truck also had less then 70,000 miles before I sold it. Lets just say I am not impressed with 6.0.
post #4 of 7 Old 01-25-2011, 10:08 AM
Quoted: 5 Post(s)
7.3 is a good engine.
there are some things that are common issues
  • Cam Position Sensor failure
  • Fuel Bowl heater shorts causing No Start
  • E4od/4r100 not the strongest transmissions lol
  • SD's had turbo surge, easily fixable w/ wicked wheel
  • HPOP lines leaking/blowing out
  • Poor fuel system design, resulting in cackle, fuel/oil starvation of #8 injector. not that big of a deal, can be solved with a reg return kit
  • Fuel bowl filter setup not the greatest for high HP apps, but just fine for mild mods and stock apps
  • injector/injector o ring issues. but the injectors are much more tolerant of dirt, water, and low fuel pressure than 6.0 injectors
but all in all, the engine is incredibly reliable, much easier than a 6.0 to work on, and parts are cheaper. If your goal is high HP, look at 6.0's or 6.4's. If you want a hoss of a truck that will keep on tickin with minimal worry, the 7.3 is a good choice. If it were me, id look at 2000 MY trucks.
Originally Posted by Ianstew
There is a difference in a government acting responsibly within their powers, and a government that just decides what their powers are and what responsibility means based on political whimsy.
ianstew is offline
post #5 of 7 Old 01-25-2011, 10:18 AM
Mr-Toche85-95's Avatar
yes 7.3 rules i have one down here in mexico and is very reliable engine and trcuk some repair need some time but nothing so bad choose a 1995 thru 2000 7.3l grat deal
dodge proof powerstroke rules
Mr-Toche85-95 is offline
post #6 of 7 Old 01-25-2011, 10:53 AM
PM me if you com across a 2001 7.3, I have The Engine Serial Numbers (ESN) for the ones with the forged connecting rods. Just an FYI, ford wanted to switch to powdered rods in 2001 and they did but they needed to deplete the stock of forged rods so certain engines came with those.
8.5" Procomp Lift
143,000 miles
post #7 of 7 Old 01-25-2011, 11:29 AM
Mob boss
Jarrod B's Avatar
Quoted: 149 Post(s)
dont. get a newer 6oh
2006 Ford F250 CCSB FX4 6.0
Sold
1997 F350 CCLB 2WD 7.3
1999 F350 CCLB 4WD 7.3
2003 F350 CCLB FX4 6.0
LSP Chapter Director
LSP Group Threads
Jarrod B is offline
