Mystery cut wires 2004 Ford 6.0 Help..... - Ford Powerstroke Diesel Forum
Old 01-19-2011, 09:18 AM
Hi Folks,
I just bought a 2004 F250 6.0 as a fixer upper and completed the Heads / bolts / HPOP / EGR Delete.
Everything went pretty smooth, but now i can't get it started...
Can the picture of these mystery cut wires indicate that the PO cut out the fuse box?
could that be why i cant get it started?
Sorry, just not that familiar with these Fords.....
Thank you
Old 01-19-2011, 09:19 AM
Illiana Chapter Director
Originally Posted by Junmity View Post
Hi Folks,
Attachment 21756
Thank you
Those haven't been cut. Our trucks come with those wires like that.
Old 01-19-2011, 09:26 AM
Is that where the fuse box should be?
or are those fuses behind the cut wires it?
Old 01-19-2011, 09:29 AM
'Merica
thats the under fuse box behind the wires.
the wires themselves are customer access wires (for tow trucks and stuff to run lights etc) there is also another set of customer access wires under the dash.
as for the no start, might take a bit of cranking to get oil to your HPOP and rails, as everything is dry.
Old 01-19-2011, 09:32 AM
Thank you!
I have tried cranking it, quite a bit.....
how long can i crank on it without hurting the starter?
Old 01-19-2011, 09:33 AM
Thank you!
Just crank it in 15-20 second intervals and let it sit for 3 minutes or so in between.
Old 01-19-2011, 09:39 AM
Come to think of it,
I think didn't add any oil to the HPOP after reinstalling it......
how much cranking would you think it would take to fill it up with oil?
Old 01-19-2011, 09:40 AM
'Merica
it would take a lil bit o time. just take er easy on the starter like dhanna said, and put a charger on the batteries.
Old 01-19-2011, 09:42 AM
Definately keep a charger on the batteries. You don't want to cause any damage to the FICM (Fuel Injection Control Module).
Old 01-19-2011, 09:48 AM
Thank you!
I'm heading out to give it a shot!
I'll keep you posted.
