Help - Ford Powerstroke Diesel Forum
Old 05-08-2006, 06:31 PM
Question Help
I have a 99 superduty work truck style with the small headlamp set up. Im wondering if the standard size headlamp will bolt up and connect electrically with no major modifications....i dont know the answer but im sure someone here does
:pray: help
Old 05-19-2006, 04:40 PM
ok i found it out. All you gotta do is change the end of the wire harness that plugs into the light and it gose in fine.
Old 05-20-2006, 06:16 AM
Gun Nut
Welcome Colt! Sorry you didn't get a response to your original post. I flat out missed it - won't let that happen again. Glad you found the fix and thanks for letting us know what it was.
