Installed Gauges. Help with my readouts - Ford Powerstroke Diesel Forum
Old 12-31-2010, 09:36 AM
I just installed GlowShift A Pillar gauges: Boost, EGT, and Tranny Temp. I just wanted to get a comparison of what other people get for readings.
The truck is a 99 7.3 4x4 auto. Basically stock other than 4" exhaust and 4" Tymar intake.
Boost: Usually around 0-5lbs. Under heavy throttle, it gets up to 15 or so
EGT: Crusing, between 300-600. I've seen it get as high as 800
Tranny: Never gone higher than 140.
Old 12-31-2010, 09:48 AM
Illiana Chapter Director
Those numbers are normal.
Old 12-31-2010, 10:44 AM
What color/tracer wire did you tap your constant power into? I have to turn on my headlights for my gauges to turn on, so the 12v constant is not right.
Thanks.
Old 12-31-2010, 04:35 PM
Thanks.
That's the way Glow Shift are. The gauge lights have to be on for the gauges to work.
Old 12-31-2010, 08:59 PM
Thanks.
I actually used an add-a-circuit in the fuse box. I believe I put it in the radio memory fuse.
I don't have to have the headlights on for them to work. They're always on. My only complaint is that they don't have any kind of dimmer. At night they're almost too bright.
Old 01-01-2011, 10:33 AM
autometers better by far IMO.. anyway thats normal for a stock 7.3.. get a chip and you'll see in the 20's for boost and egts a lil higher at WOT. my tranny likes to sit at 125, but i have two coolers..ha.
