Help No parking lights or instrument lights - Ford Powerstroke Diesel Forum
Old 12-27-2010, 02:45 PM
Send a message via AIM to S.S construction
Started truck everything was working put it in drive instrument lights stopped working then noticed parking lights were out checked fues all were good i even changed them out what could it be.
Old 12-27-2010, 03:08 PM
Any ideas would be great
Old 12-27-2010, 03:55 PM
what year is your truck my 02 did that it kept on popping a fuse it was my trailer shorting out my running lights,i think the older trucks 99-01 have fuses under the dash and hood
Old 12-27-2010, 06:42 PM
my trucks an 2002 f-350 i now have noticed the auto head lights aren't working either i have check all the fuses but they are all good. Could the switch be bad? I still have head lights and fog lights .
Old 12-27-2010, 06:51 PM
BUMp BUMP BUMP
Old 12-29-2010, 01:59 PM
I am ready to give up. well found the auto lights are good. But still no park lights or instrument lights checked all fuses and relays i could find are there others i could check? help please
Old 12-29-2010, 04:13 PM
Someone has to have an idea on this
Old 12-29-2010, 04:22 PM
Illiana Chapter Director
Have you checked the back of the switch where the harness plugs in? The parking lights work off a different wire than the others. Take a test light and see if you have any power from any wires in the parking light only position.
