Most common problems with a powerstroke 7.3 - Ford Powerstroke Diesel Forum
post #1 of 6 Old 06-26-2010, 09:09 AM Thread Starter
95flatbed's Avatar
Cool Most common problems with a powerstroke 7.3
Hello all,
Being new to diesels I would like to know what some of the most common problems that people have with diesels are. Since all my experience is with gasoline engines, I would like to know what to check if my truck were to die out of the blue. Let's say my '95 F-250 PSD dies on me, I check that I have fuel and it still cranks over but just doesn't start. What would you check next?
Thanks for helping a newbie
~Z
95flatbed is offline
post #2 of 6 Old 06-26-2010, 09:20 AM
DirtyDiesel's Avatar
Quoted: 4 Post(s)
WELCOME TO THE ORG.
7.3's r notorious for the cam position sensor going out. if it jus up and died then thats the 1st thing id check. a good idea to always keep a spare in the truck.
Brett
'08 Ford F-350 Powerstroke Lariet 4x4
SPARTAN Tuner, Flo-Pro 5" Exhaust 6" Tip, Deleted, S&B Intake, B&W Hitch, 2.5" Leveling kit, Custom Rear Traction Bars, 20x12 FUEL NUTZ, 33x12.5 Toyo MT's, PIONEER Screen, 3500W of ORION amps, Sundown SD3 10" subs, Blacked out Headlights, Retro LED bulbs, Recon Mirror Lights
DirtyDiesel is offline
post #3 of 6 Old 06-26-2010, 09:34 AM Thread Starter
95flatbed's Avatar
Okay, thanks DD how much do those cost? and is there a way bypass/hotwire it in an emergency situation? (middle of the desert)
~Z
post #4 of 6 Old 06-26-2010, 09:41 AM
they're like 30 bucks. anywhere. keep one in your glove box!
Dietoremain is offline
post #5 of 6 Old 06-26-2010, 09:43 AM
Quoted: 4 Post(s)
~Z
lol, no the CPS for these motors is like a distributor in a gas motor. if it doesnt work the motor doesnt run.. the CPS is wat tells the computer when to fire the injectors for each cylinder.
Brett
post #6 of 6 Old 06-26-2010, 09:47 AM
Send a message via Yahoo to harley1rocker Send a message via Skype™ to harley1rocker
also the icp has been known to make em quit.when faulty of course.the heater element in the fuel bowl grounds out, sometimes the wire comes in contact with the bowl.your fuel sucking air,trash in the pickup foot.(in the tanks..but first thing to look at would be the cps sensor
harley1rocker is offline
