Go Back   Ford Powerstroke Diesel Forum > General Topics > General Diesel Discussion
Old 04-12-2007, 11:39 AM
benjiyam benjiyam is offline
What's the rpm at highway speed
I,
I'm looking into buying a 1999 4 door, dual RW F-350 with 7.3L PS. I have test driven the truck and at 60MPH it is running at 2500 RPM , is this normal for that truck. It as a 4 speed automatic transmission. The truck only as 70 000 mile (110 000km)
Thanks,
Benjiyam
Old 04-12-2007, 11:43 AM
Dave Dave is online now
sounds about right for 4.10 gears. Does it have 4.10's or 3.73's
Old 04-12-2007, 11:50 AM
Banshee34 Banshee34 is offline
Pay it Forward!
I run over 70 at 1999 rpm's???
Old 04-12-2007, 11:58 AM
cblackb cblackb is offline
Yeah with the deep gears she's gonna be wound up decently high at highway speeds. I've got 3.55's or 3.73's I can't remember..but I run around 1800 at 65. Your mileage will suffer but it'll pull like crazy.
Old 04-12-2007, 12:20 PM
MrJohnWayne MrJohnWayne is offline
Thats Mr. Oil Leak.....
I've got the same truck (except I have a 6 speed.) It has 4:10's. At 70 mph I'm running 2350 2400 RPM's
Old 04-12-2007, 12:45 PM
Thanks for your answers,
In conclusion with a 3.73 = 1800 RPM at 60 MPH
withe a 4.1 = 2300 RPM at 60 MPH
Old 04-12-2007, 01:10 PM
Maintain Maintain is online now
1/4 mile shot
Send a message via AIM to Maintain
With 4.10's and the stock 30-31" tires at 60mph with 4.10's you should still be just a tick under 2,000 RPM'S. Unless you have an OBS 10.25" rear axle - you have 3.73's from the factory.
This sounds about right... HOWEVER the Auto will run lower RPM's then the 6 speed in it's final gear since the auto's O/D is .71 and the 6spd is around .8 something... The #'s might be SLIGHTLY off...
My conclusion is that the truck has TINY tires on it - around 24" tall. Probably not.
The gears have been changed... to something as high as 4.56's. Possible.
You were driving around in 3rd gear (with O/D off). Most likely.
At 60 with a rear axle ratio of 4.10 with 32" tires in 3rd gear you'd be running 2500-2600 rpm's.
Old 04-12-2007, 01:18 PM
95PDXLT 95PDXLT is offline
Agreed
my guess is 4.10 in drive with a slighty larger tire than stock. I had an 89 7.3 with 4 speed manual no o/d and with the stock tires it spun 2600-2700 @ 60mph.
Old 04-12-2007, 01:55 PM
PSDfan99 PSDfan99 is offline
blub blub blub
i have a 99 and its got 3.73's and i can go 70mph at exactly 2,000 RPM
Old 04-12-2007, 02:43 PM
Ok I got curious and went for a drive. At 70 mph I'm not quite to 2000 RPM and I'm running stock tire size of 265/75/16's. I think I do have 3.73's. Yeah you may want to verify that you're indeed in OD and not 3rd.
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
