power steering pump removal??? - Ford Powerstroke Diesel Forum
Old 01-01-2010, 05:41 PM
i want to know if any of you has removed a powersteering pump on a 7.3, and is it hard to do. does any one have a write up on how to remove it, becouse i am tired of the hard steering and i want to change the pump.thanks.
Old 01-17-2010, 05:04 PM
bump
me too
Old 01-17-2010, 05:05 PM
ADMIN AND TECH
replacing the pump if you are trying to fix the hard to steer sitting still concern , will not fix it
Old 01-17-2010, 05:14 PM
duct tape & zip ties
I aggree with scuffy on what he is saying.
As for replacing the the pump it is not that hard to do.
What I do is remove the aluminum mounting bracket with the pump attached to it.
All you have to do is remove the belt from the pulley, remove the lines attached to the pump. Then remove the three bolts holding the bracket to the engine. Then you can pull the pump and bracket out as one piece.
Then clamp the bracket into a bench vise. Using a power steering pump pulley puller remove the pulley. Then dismount the pump from the bracket. Then install the new pump.
Once everything is reassembled. Jack up the front end fill the reservior with fluid. If it was red when you removed the pump. You need to use dexron ( transmission fluid), if it was clear or yellow then you use power steering fluid. Once the reservior is full of fluid. With the engine off, you turn the tires full lock right, then full lock left. You keep doing this until all the air is bled out of the system.
The reason for jacking up the front end is to make it easier to turn.
Old 01-17-2010, 05:19 PM
mine is whining and leaking. Turns fine.
Thanks bigcountry, i just found an earlier post of yours that said the same as above.
Ha ha, at least your consistant.
Thanks
Old 01-17-2010, 05:40 PM
It is alot easier to remove the pulley with the puller if you have complete access to it. I tried to do it, when the pump was in the truck. I got poed and pulled the whole bracket off.
Old 01-17-2010, 05:52 PM
goin to auto zone in the morning.... then roll up the sleeves.
