issue with my powerstroke need help - Ford Powerstroke Diesel Forum
post #1 of 8 Old 12-31-2009, 03:46 PM Thread Starter
snakebite03's Avatar
I have a 2000 F350 7.3 Powerstroke and I'm having a issue with it that im trying to solve and I was hoping you guys on here could be of some help.
The first problem I'm having is when the truck is started after sitting over night or all day it will idle around 1000 rpm and wont go down tell the truck is warmed up all the way or tell i touch the gas peddle.
The second problem I'm having is lost boost. If I start driving my truck before its warmed up all the way my boost comes and go's but once the truck is warmed up 100% the boost is fine.
Ford told me the issue was the back presser control valve and a clogged tube leading to the valve so $100 bucks later i replaced the old valve with a new one and I cleaned out the tube. Well the issue seem to get a litlle better but not by much.
Any help on what to try next or anyone know what the issue is please chim in
snakebite03 is offline
post #2 of 8 Old 12-31-2009, 04:03 PM
Cjcross22's Avatar
Its the EBPV, its normal and fine. You can gut it or wire it open if you dont like it. Problem will go away when it warms up.
-Cory
Y2K
F250 XLT 7.3L ECSB SRW ZF6 4x4
Cjcross22 is offline
post #3 of 8 Old 12-31-2009, 04:32 PM Thread Starter
ive owned this truck for 4 years and its never done this tell now and when it dose my exhaust temp shoots to 1200 degrees and the truck wont go over 35 mph so i dont see how its normal
post #4 of 8 Old 12-31-2009, 04:35 PM
Sounds like the controller for it isnt working. i say unplug the EBPV and see what it does.
Dietoremain is offline
post #5 of 8 Old 12-31-2009, 04:42 PM
WNY Biodiesel Co-op
greasyF250's Avatar
Quoted: 6 Post(s)
The high idle is normal for cold weather. mine does it too.
2000 F250 King Ranch Crew Cab 7.3L LB 4X4 100% home brewed Biodiesel
ZF6 6SPD trans
Zoo Dad Mod
DP F5 Tuner
Wicked Wheel
AFE Intake
4" straight exhaust with 5" tip
Isspro 3 Gauge Pod
285/75/16 Cooper ATP on factory 16's
Banks Big Head
298K
greasyF250 is offline
post #6 of 8 Old 12-31-2009, 04:51 PM
Cjcross22's Avatar
You never said that about your temps and about not letting you get over 30 mph... so it is normal minus that junk.. not sure now, mine does it over 30 mph so must be another problem.
-Cory
Y2K
post #7 of 8 Old 12-31-2009, 04:53 PM Thread Starter
oops sorry that was my bad
post #8 of 8 Old 12-31-2009, 05:01 PM
Cjcross22's Avatar
Its all good, but the EBPV closing shouldn't stop you from going over 30 or at least it doesn't stop mine... as far as temps I have not ever really looked at my temps while it was on.
Someone will chime in and help ya out more in a few I'm sure.
-Cory
Y2K
