Omega Air Horn make no Hoot Hoot!!!
Ive got the Omega Air Horns, the Tri Set up. FInally got a compressor today and hooked it all up with no leaks everything went smooth, then went to go blow the horns and all I got was air... Took them apart and there was some dirt and what not, well cleaned the crud out of it, put it together and still nothing but air, PSI is sying bout 100 or 125 and still air. What else? And the solenoid seems to work fine, took that apart and everything works....Hmmmm
So if I understand this correctly, when you go to honk the horn, you get air out of the horn side of the solenoid but no honk honk from the horns?
--Snake |
