Buying a new(used) truck - Ford Powerstroke Diesel Forum
Old 12-22-2009, 01:05 PM
JLK JLK is offline
Being as this is powerstroke.org, I think I may know what's going to win here, but here's my situation:
I'm in the market for a used truck but on a bit of a budget, I will be hauling a small cargo trailer and truckin around my quad once in a while - but my main need is to expand my snow plowing business - so I have 3 options I'm looking at right now:
1. Buy a newer F150 (2008ish) with the 5.4
2. Buy a bit older F250 (2007ish) with the 5.4
3. Buy a bit older F350 with a diesel (either the 7.3 or 6.0, 200-2005)
I'm currently doing small jobs plowing with an atv and want to get into bigger stuff next year. So with that in mind, what do you think is my best option?
Old 12-23-2009, 04:10 AM
Like any business, do a cost/benefit study.
The big question is: gas or diesel? Gas engine will cost less initially. Oil changes are cheaper - it's about $100 to change the oil on a PS using Rotella synthetic. Diesel uses less fuel, it's safe to say about 25% less, while right now diesel is maybe 5-10% more than gas. Diesel uses a bit less fuel at idle, too.
Consider weight of the trailer. If you're towing a lot and the trailer weighs more than 6k pounds, the F250 or F350 will pay off. Just better towing platforms.
Small point, but something to think about: you look a bit more professional with a larger truck if you're using it for business.
In 05, they tightened the turning circle of the PS. Something to think about if you want to put a snowplow on the truck.
Old 12-23-2009, 07:40 AM
JLK JLK is offline
Hmm...some interesting points....thanks JohnO
