mixing urea with diesel? - Ford Powerstroke Diesel Forum
post #1 of 9 Old 12-16-2009, 05:08 AM Thread Starter
DMR
i guess its for emissions? anyone know anything about it?
DMR is offline
post #2 of 9 Old 12-16-2009, 05:33 AM
Send a message via AIM to kx592
Well what is a urea injector that people are talking about?
1997 7.3 extended cab 8ft.
4" straight piped
DIY intake- 6637 filter
178K on the dash
Boost, PYRO, Trans temp gauges (auto meter)
33" nittos on stock height
kx592 is offline
post #3 of 9 Old 12-16-2009, 05:35 AM
02PUFFER's Avatar
It gets sprayed in the exhaust, and if I understand it correctly, its like a liquid, refillable catalytic converter. It just reduces emissions.
Craig
2002 F-250 7.3L 4x4 SC/LB Lariet
02PUFFER is offline
post #4 of 9 Old 12-16-2009, 05:35 AM
ryandamo's Avatar
the way i understrand it is that they shoot the urea into the exhaust pipe right before the diesel particulate filter and its supposed to help clean it.
2016 F450 6.7L XLT 4x4Dump, bone stock
1994 F250 7.3L XLT 4x4 ZF5 , Centurion, 4" Lift, 6637, Gulf Coast Bypass Filter, Big fuel tanks, dana 60 swap, No longer dually
1997 F350 7.3L XLT 4x4Dump, E4OD, 4 in exhaust, TS 6 position, 3/8 Trans line+external filter
2013 Scag Turf Tiger 61" 1.1L Caterpillar Diesel
1960 John Deere 440 Backhoe 2-53 detroit
ryandamo is offline
post #5 of 9 Old 12-16-2009, 01:21 PM Thread Starter
DMR
screw that.
DMR is offline
post #6 of 9 Old 12-16-2009, 05:48 PM
Oh ok Ive hurd of that but didnt know they had a name for it yet, I thought they refured that as just part of the DPF on new truck, good to know though thanks
4" straight piped
178K on the dash
kx592 is offline
post #7 of 9 Old 12-18-2009, 04:15 AM
JohnO's Avatar
dang, for a minute there, I thought they had found a way to run a PS on pi$$.
Now, there's a thought...
"Big Duke": 06 F350 King Ranch
long bed, crew cab, dualies
JohnO is offline
post #8 of 9 Old 12-18-2009, 10:41 AM
It's not mixed with the diesel!
Theres a Good Write up in Diesel World mag,on the Motor and a Follow up on the page after that about the Urea and how the Exhaust system works you guys should check it out!
This Bad Boy 6.7 even has two Cooling systems! One pump on each side of the motor!
one runs around 122 degrees for some of the stuff on the motor and the other runs i think it was 194 thats the main cooling for the motor..... the write up has all the Info thats out for the motor right Now! far as I Know!
Lead Foot is offline
post #9 of 9 Old 12-18-2009, 10:46 AM
That is a Thought
If you where running Water injection and Pi$$ed in it i wonder How that would Smell to the tailgaters
I can Hear them Now " He's Running the Pi$$ out of that Ford I Smell it"
