Strange Vibration
I have a 97 F-250 4x4 7.3L Auto. I recently noticed a new vibration in the engine with the RPM between 1950-2100. Above 2100, the vibration dissapears. Its a fine vibration that is present anytime the engine is between those RPMs; In park, Neutral or shifting up. I don't hear any squeaks or grinding when the vibration is present, or when its at idle with the hood up. I had one sticky idler pulley bearing thats been replaced.
I'm looking for any suggestions. Thanks, Casey |
pull the belt off and see if it still vibrates.
I pulled the belt off and noticed a definite decrease in the noise and less vibration. With the belt off, when i spin the fan blade, I hear a distinct medium pitch groan coming from the water pump. If I push/pull on an edge of the fan blade there is noticible play in the pump. Im guessing these are not normal and should replace the water pump. Thoughts?
sounds like you got a winner
Well, after all that (changing the water pump), the vibration decreased, but is still there. The PS pump seems to turn smoothly but has a decent amount of resistance. The PS pump has about 3/16 play in and out, but no play up and down. Think it needs to go also?
nope that's normal to have that kind of play.
The alternator doesn't have any play up/down, in/out but squeaks a bit when I turn it by hand. The only things left are the balancer and the vacuum? pump near the PS pump. Any recommendations? I realize this vibration probably isn't a huge deal, but its driving me nuts. Thanks for the info so far!
is the vibration totally gone when the belt is off?
The vibration is definetly present with the belt on or off. I noticed today that the RPM range is increasing and I feel a series of different vibrations on the floor under the brake pedal as the RPM increases/decreases. I'm going to crawl under there and see if something is loose and touching the floor or frame or if a mount is broken.
I wasn't able to see anything rubbing on the cab or frame, and the mounts don't have any obvious fractures.
When I run the engine up in neutral to 2000 rpm, the rpm will drop by 300-400 without any change in throttle position on my part. I have to depress the throttle again to get the rpm back up to 2000. I got the same drop when trying 1500 rpm and 2500 rpm. I changed the fuel filter recently BTW. |
