6637 filter cleaning
Hey I know alot of guys are running the 6637 filter on there trucks, also called the tymar filter? Anyway was wondering if you guys clean them or replace them? Mine is getting a bit dirty and dont wanna waste money on a new one if your cleaning them. Thanks
I believe that you have to just replace them because it is a paper filter. Hopefully someone else will chime in here too
They are not technically a reusable cleanable filter. However every now and then i take it off and blow it out with an air compressor. Blow from the inside otherwise you just drive the dust deeper into the filter.
Replace .
Just replace that filter with a brand new one. |
![]() Never use air. Don't try to clean a paper filter. They are disposable. |
If you don't blast the air straight on it it wouldn't be much different than the engine.
Except the engine is creating a vacum from outside to the inside of the filter and it is certainly not 90, 120, 100 psi as with you air compressor output
Thats why i hold it back a ways. Don't get me wrong, im not sayin this is the way you should always do it, but if youve got alot of bigger stuff on it, you can blow that off pretty easy.
If your carefull you can use an air bomb to clean them. We use it on all of our equipment and have never had any trouble with it.
