My other truck. - Ford Powerstroke Diesel Forum
post #1 of 2 Old 03-12-2006, 05:12 PM Thread Starter
overl0rd's Avatar
My other truck.
Figured I'd stick this in here since it's not a pickup or a Powerstroke but still a T444E. My work van is an 01, intercooled. It's a strong runner but it's goverened to 65 miles an hour. Only problems I'm having with it are it weeping a little coolant from the gasket behind the water pump and it blows blue smoke in first and second gear, and I'm not sure what's causing it. The mechanic is going to take care of the coolant but I'm trying to get a little more insight into the smoke before I write up the work order. I'm thinking it could be the turbo, but I want to get a footing before I jump into the doghouse. Any of you 99-03 guys have this issue?
'96 F250 4x4 Ext Cab, 5 speed. K&N FIPK - modified to use 6637; 3" downpipe, 6" stack; Beans modded IDM; Beans stage 2s; shimmed FPR; exhaust brake; 6 position TS; locked 4.10s
'93 F250 4x4 regular cab long box. 7.3IDI nonturbo/E4OD 8' Western. STAYING STOCK
'65 Pontiac Tempest, 406ci chevy small block, TH350 with shift kit, 2700 stall converter.
'01 HD XL1200S - Lots of Screamin Eagle goodies
'96 Tbird LX V8
Progressive loves me
overl0rd is offline
post #2 of 2 Old 03-12-2006, 09:40 PM
99Smokin73Stroker's Avatar
Send a message via AIM to 99Smokin73Stroker Send a message via Yahoo to 99Smokin73Stroker
I thought blue smoke was most likely caused by blow-by...??
2005 F350 XLT FX4. 2.5" leveling kit, 03 turbo, 4" MBRP Turbo-back, 58v FICM, SCT X4, Irate Diesel coolant filter
99Smokin73Stroker is offline
