need dodge help: 24valve - Ford Powerstroke Diesel Forum
Old 11-15-2009, 03:45 PM
Send a message via AIM to Strokeorcroak Send a message via Yahoo to Strokeorcroak
I need some tips from you dodge guys: my buddy has a 24 valve completely stock..
I told him to do a 5" exhaust straight and then a smarty.
Is there a better chip/programmer out there for the 24 valves than the smarty? What other mods does he need?
Just give me some input on what he should do... he was thinking an edge or a dynamite?? Is edge bad for the dodge as it is for the ford?
Old 11-15-2009, 04:05 PM
Dodge Cummins Diesel Forum
j/k
Old 11-15-2009, 09:31 PM
There has to be someone on here that knows. I dont want him buying anything ****ty. And i also know the 24v can be scary fast with the smarty. Any info guys?
Old 11-16-2009, 12:09 AM
Make sure he has a good lift pump and a fuel pressure gauge. If he still has his stock lift pump, just tell him to buy an extra VP to carry around. As far as I know, the smarty is the best choice for the 24 valves.
Old 11-16-2009, 01:15 AM
theres another tuner i cant remember what its called, i'm more old school when it comes to cummins i like the 12v's but then again i'd rather have my international T444E any day
Old 11-16-2009, 01:57 AM
Send a message via AIM to lifted 350
Smarty is better for the 5.9 common rail's, which are 03 to 07 i believe. If it is a 6.7 I really do not know much about them sorry... Earlier 24valves, like 99 up run better off the Quadzilla programmer's then Smarty. But you are on the right track with a programmer/chip, intake and exhaust.
Old 11-16-2009, 02:03 AM
tell him to pull the cummins out and drop a caterpillar diesel in it LOL
Old 11-16-2009, 04:42 AM
Berm Buster
My dad has a vp44 pumped and his quadzilla works very well with that. He also has about 10k worth of other $hit but.
What year is the truck. I have learned alot about the cummins seeing as my dad, brother, and grandpa all have one
Old 11-16-2009, 09:47 AM
Yeah i got on the cummins forum and found that the quadzilla is best for the 24v, but its also like 700 bucks lol.
And then the smarty is best for the common rail 5.9's....
That damn quadzilla adrenaline will put like 180hp/4xxtq to the truck.. how the hell is 400 lbs of tq ADDED to the stock numbers even possible lol??
Also whats the big difference between cummins and powerstrokes lift pumps? Why is it such a big deal on the cummins to upgrade it or stay out of the throttle?
Old 11-16-2009, 09:54 AM
say no to rolling coal
The injection systems between the 2 brands are completely different. On the cummins and duramax motors adding a lift pump is very important when considering making a lot of power. The injection pumps are under the hood and have to pull fuel a long way from the tank, then turn around and push it at extreme pressure to the fuel rail or injectors. A lift pump simply cuts the injection pump work load in half. Starving a VP, CP3, or even a P pump is a bad idea...
