Pyrometer question - Ford Powerstroke Diesel Forum
Old 11-12-2009, 10:34 AM
Question Pyrometer question
OK, so I'm new to the 7.3 world. I know this thing is measuring heat, but what exactly... exhuast?
How should I be using this guage ~ what's normal?
Did Ford put this in or are these guages strickly aftermarket ~ and does this indicat that the truck was chipped at some time?
Appriciate any help
Scott
Old 11-12-2009, 10:41 AM
wriott
Guest
Posts: n/a
egt gauges tell you how hot the exhaust is... this tells you if you are running to hot so you can back out of it with out causing damage... as in melting the motor. 1250* or below is the safe limit for any extended periods, anything over that should only be done in SHORT bursts. the gauges are aftermarket only and were not installed factory. the gauge will not tell you if its been chiped or not. it only tells you what the exhaust temps are at that exact moment
Old 11-12-2009, 10:53 AM
Thanks! It never seems to go past about 650, but I havent had the stock trailer on yet and haulin up a hill...
S
Old 11-12-2009, 11:02 AM
with wroitt. You can find the probe tapped into one of two spots. Either its screwed into the exhaust manifold (usually the driver's side) or it's in the down pipe after the turbo. Many people install it in the manifold where it's more accurate.
Old 11-12-2009, 11:28 AM
wriott
Guest
Posts: n/a
if its in the down pipe i would highly recommend moving it to the driver side manifold
Old 11-12-2009, 11:38 AM
I'll have to check it out Will...What will I be looking for... I'm imagining a threaded probe with 2-3" inside the pipe and 1-2" sticking out with a wire harness attached...?
Old 11-12-2009, 11:54 AM
Should look something like this....
Old 11-12-2009, 11:55 AM
If it has never been over 650* it is either messed up or in the downpipe
Old 11-12-2009, 04:54 PM
Or he drives it like my grandma rides her moped!
