washing underhood - Ford Powerstroke Diesel Forum
Old 09-30-2009, 03:46 AM
washing underhood
well, after I hit a few monster puddles mudding, the whole engine compartment is filthy. can I just hitit with a pressure washer, or is a hose better?
any spots to stay away from? it looks bad, and I need to do a cleanup. thanks for any advice
Old 09-30-2009, 05:21 AM
I personally would not use a pressure washer on any engine bay. It may not be harmful, but I just wouldn't take the risk. I'd stick with using some sort of mild degreaser and a garden hose.
Old 09-30-2009, 08:11 PM
okay. so I was gonna use some concentrated simple green.
I've used it before and it works great. I also have a few cans of aresol engine degreaser.
other then that, its okay to get everything wet?
Old 09-30-2009, 08:21 PM
it is fine to get everything wet... there is a product called grease lighting which works well... i have used it many times.....
as for water... make sure the engine is running and you can use a pressure washer or a garden hose without an issue...
Old 10-01-2009, 07:49 AM
Cleaning Engine Bays
Everytime I pressure wash an engine I always get an electrical gremlin. I now hand wipe everything off with a damp clean cloth.
Old 10-01-2009, 07:51 AM
i would suggest that the engine is not hot when doing it.
Old 10-01-2009, 08:32 AM
Send a message via AIM to Ewils35
whats the fun with out that
Old 10-01-2009, 09:31 AM
yeah not hot, but running none the less to burn off any water that does make its way where it shouldnt be....
Old 10-03-2009, 06:53 AM
Ill tell you what I do if you want a clean engine bay. Use the degreaser like everyone else said. After you get it clean you can spray tire shine all over under your hood then wipe it down with a damp rag to get all the drips your engine bay will be CLEAN!
Old 10-03-2009, 12:20 PM
Tire cleaner does work very well
