ts performace chip - Ford Powerstroke Diesel Forum
post #1 of 6 Old 09-03-2009, 07:49 AM Thread Starter
Send a message via AIM to kyleh20
ts performace chip
hey i have had my chip for about 3 months now and every time i let off the gas at certian points it will bog down and couph it only stalled twice but why would this be? air/ fuel ratio is off?? do i need to get it retuned?
2002 F-250 7.3l 190K
str8 piped exhaust
T4 mount s366 turbo
6637 W/ zoodad
TW custom tunes
18" rockstars with nitto terra grapplers
Pioneer avic-f700bt
Piller mount gauges autometer pyro/boost/tranny
F650 dash w/ fuel pressure and air pressure
Fisher 7.6 HD plow
BTS Transmission
And lights everywhere
kyleh20 is offline
post #2 of 6 Old 09-03-2009, 08:14 AM
szyd's Avatar
Is it a TS chip with TS tunes or a TS chip with custom tunes?
Did You clean the board good before installing?
Did you give the PCM code when ordering?
Are you seeing a CEL when the truck is acting up?
Dale
99.5 F 350 Totaled
2000 F350 Lariate
CC
SB
4x4
4" turbo back
cold air. Zoodad
Banks big head
Wicked wheel
4" BDS lift. With Bilstein's
all brought together by TW
szyd is offline
post #3 of 6 Old 09-03-2009, 01:15 PM Thread Starter
I believe it is a custom tuned chip not a tuner and it is not reading any codes when it happens and I did not give ecm code when ordering it was never asked for what would that have done and I also thought that it could be not cleaned properly so I took it all apart and recleaned and made sure it is clean
str8 piped exhaust
T4 mount s366 turbo
6637 W/ zoodad
TW custom tunes
Pioneer avic-f700bt
Fisher 7.6 HD plow
BTS Transmission
kyleh20 is offline
post #4 of 6 Old 09-03-2009, 01:32 PM
Powerstroke W/smoke's Avatar
You want to make sure that both circuit boards (the chip and the PCM) are extremely clean on both sides.
Sold!2001 F-350Lariat Lifted 7.3L CC, 5" Straight Pipe, DIY Intake, Foil-Delete, 6 pos chip, CCV Bypass, 37" Toyo MT, Gauges, Blacked out, 07 Harley Front-End.
SOLD!2006 F-250Amarillo 6.0L CC, 4" Straight Pipe, SCT-II
STOLEN ,2001 F-350Lariat 7.3L CC, 6pos chip, 4" Banks Straight-Pipe, Banks Comp Wheel, Custom Lighting, Foil-Delete, Intake.
Powerstroke W/smoke is offline
post #5 of 6 Old 09-03-2009, 06:01 PM
szyd's Avatar
Whos tunes?
Does the truck act up with the chip not pluged in?
A chip will make pre exsisting problems very apparent.
Dale
99.5 F 350 Totaled
2000 F350 Lariate
CC
SB
4x4
4" turbo back
cold air. Zoodad
Banks big head
Wicked wheel
szyd is offline
post #6 of 6 Old 09-04-2009, 06:17 AM Thread Starter
it as bought from raul at stealth automotive so who ever he uses i believe it is tw but no it does not do it when the chip is plugged in which is why i believe it is related to the chip no properly tuned to my truck
str8 piped exhaust
T4 mount s366 turbo
6637 W/ zoodad
TW custom tunes
Pioneer avic-f700bt
Fisher 7.6 HD plow
BTS Transmission
kyleh20 is offline
