Go Back   Ford Powerstroke Diesel Forum > General Topics > General Diesel Discussion
Old 02-22-2007, 06:14 PM
BadF250Boy99 BadF250Boy99 is offline
Send a message via AIM to BadF250Boy99
making a 2wd a 4wd
just curious i searched around for a bit without a answer
has anyone converted a 2wd truck to 4wd on here im sure someone has but im trying to decide if its worth it i have a lower mileage 99 extended cab longbed in good shape all around except the 2wd part
Old 02-22-2007, 06:21 PM
bigcountrysg bigcountrysg is offline
Countryboy Mechanic
Not worth the time man. It is easier and cheaper to buy a 4 wheel drive.
Oh by the way fellow michigander, your not to far if you need help wiht your truck give me a hollar.
Old 02-22-2007, 06:22 PM
ncbowhunter ncbowhunter is offline
ive heard that the 2 wheel drives use a frame that is not as stong as 4 wheel drives, this from an old mechanic i used to know when i was a teenager, not sure if there is anything to this or not. just my thoughts.
Old 02-22-2007, 06:27 PM
pipelayerjdh pipelayerjdh is offline
MINI-MOD
Lift the 2wd, get winch and rock-on!
Old 02-22-2007, 06:33 PM
im more into modifying my 2 cars ive got 2 thunderbird's a 94 supercharged one and a 95 v8 so i bought this as a daily driver and a tow vehicle but someone called my truck a sissy little 2wd today so it got me thinking
Old 02-22-2007, 06:35 PM
bigcountrysg- your not far away at all ive ended up in willis a few times here and there
Dave Dave is offline
Broken shoulder mod
its been done but its alot more work than you need to do and its expensive
1st you need new front axle
2 new tranny or rebuild with the 4x4 output shaft
3 transfer case
4 two new driveshafts
Also you need to make sure the gear ratio in the rear and in your new front end are the same
i believe i just listed about 7500 to 9500 worth of parts
i would just by the 4x4 to begin with
Old 02-22-2007, 06:45 PM
MINI-MOD
You can lift it and be lighter than a 4wd and still look good. It is getting harder to tell the difference in a 2wd and 4wd unless it has stickers on yhe side. Of course that's not the case with the straight axle Fords, but I think it would be the way to go.
Old 02-22-2007, 06:47 PM
Countryboy Mechanic
hey BadF250Boy your in luck if you want a 11 second T-bird like I used to race at Milan drag way. I had a 85, 86 and a 91 if you ever need help let me know. I got a 30 x 40 work shop behind my house and a truck with a trailer.
Old 02-22-2007, 07:01 PM
heres some picture of the truck and cars
http://www.sccoa.com/forums/attachme...6&d=1164126609
http://www.sccoa.com/forums/attachme...7&d=1164126609
http://www.sccoa.com/forums/attachme...8&d=1164126609
http://www.sccoa.com/forums/attachme...9&d=1164126609
95
http://www.sccoa.com/forums/attachme...0&d=1171152747
http://www.sccoa.com/forums/attachme...1&d=1171152747
94
http://www.sccoa.com/forums/attachme...9&d=1163210018
http://www.sccoa.com/forums/attachme...1&d=1163210018
http://www.sccoa.com/forums/attachme...2&d=1163210018
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
