Water Pump and Maintenance
Hi - Thanks for the help with the stalling problem that I had. While replacing the sensor, I noticed the Water Pump leaking. I'll be replacing it soon. Since I need to take out lots of stuff to get to it, I will be doing other maintenance while I am in there...110K on the Excursion...
Here is what I am thinking I should replace: 1. Water Pump $249 2. Thermostat $22 3. Belt $26 - should I do the tensioner? 4. Upper Hose $13 5. Lower Home $19 6. Power Steering Pump $140 - It is also flakey Can anyone recomend other maintenance while I am in there? Powerstrokeshop.com seems to have decent prices for oem parts...do you guys like OEM or other? I can save a couple $$ (maybe $125) by not getting oem, but I do not want to do the job twice... BTW - this has been the greatest car ever! Other than diesel and oil, i've never done anything to it! |
Thanks! As soon as the rotten snow that fell this week melts, i'll be spending the day ontop of this PSD.
Looking for Tech Article on Water Pump Replacement
Sorry all, I have searched for the "H2O pump replacement article in the tech files" without much luck.
What am I doing wrong? Thanks!!! |
sounds like got most of the bases covers grab some of the coolant additives from the dealer and besure to add that in there with the new coolant
