Turbo issues?!? - Ford Powerstroke Diesel Forum
User Tag List
post #1 of 11 Old 08-01-2014, 04:45 PM Thread Starter
Angry Turbo issues?!?
I have a 2011 Ford F250. I have recently added a 4 inch flow pro and H and S minimax tuner. I was recently driving home and the turbo gauge on the dash maxed out and the HMS tuner red zero boost. The turbo was not working at all. I pulled the codes off the H&s p0340 which I believe is the cam sensor failure and p06A7 which I believe is the map sensor failure code, I let the truck sit over night after getting the codes off of it. Went out to the truck in the morning and it started up and was running fine. I replaced the map sensor today and it was full of carbon. Drove the truck for about 20 miles and then once again the boost gauge in the truck went full-scale and the HNS went to zero boost in the turbo was not working. Again with the same codes. Any information and/or ideas would be greatly appreciated thank you.
F250guy42077 is offline
post #2 of 11 Old 08-03-2014, 06:49 PM
Dirtboy64's Avatar
Quoted: 4 Post(s)
There is wiring connection on top of the intake..make sure its plugged in good. Forgot to plug mine back in when i did my delete,caused the same issue
Dirtboy64 is offline
post #3 of 11 Old 08-04-2014, 03:27 AM Thread Starter
what plug are you talkin abt? i have look an i think i have made sure all conections are tight. it is really weird acting!! thanks for the info greatly app!
post #4 of 11 Old 08-04-2014, 11:02 AM
If you are going to keep running the "H&S" Tuner, I would highly recommend looking at going to a different turbo like the Garrett GT-37 that is on the 2015trucks. Before long, your turbo is going to let go Sir.
2014 Ford F-250 Super Duty, 4WD, Crew Cab, Lariat Ultimate, FX4 6.7 "Scorpion" Turbo Diesel
John_P is offline
post #5 of 11 Old 08-04-2014, 01:27 PM Thread Starter
yes thats what i am hearing abt the H&S tuner eating up the turbo on the 2011s.. im lookin for a turbo package to put on it now, thanks for the heads up!!
post #6 of 11 Old 08-04-2014, 04:49 PM
If i'm not mistaken, the early H&S tunes where killing turbos. They've long since change the tuning to stop that.
2012 Super Duty CC SB Lariat 6.7
Line-x Bedliner, 5% Tint, Carli Suspension Lift, 20x10 American Force Wheels "Rebel SS". Toyo M/T's
Dose is offline
post #7 of 11 Old 08-04-2014, 05:24 PM
Dirtboy64's Avatar
Quoted: 4 Post(s)
Its on top of the black plastic cover in the center of the engine
post #8 of 11 Old 08-04-2014, 06:48 PM
The one in between the heads, in front of the turbo is the plug I didn't get seated all the way and the truck was actin the fool.
2012 F250 CCSB 6.7 (3.73 gears) H&S Minimaxx (My own tuning), H&S 64mm turbo kit, H&S Dual Fueler, H&S Low Pressure Fuel System, H&S CCV delete, No Limit s2 Intake, PMF 3-link, PMF traction bars, Fox 2.0s, Icon 2.5" coils, Platinum 20s w/ 295/65 toyo at2s, Airlift bags and wireless controller, TFI 50gal, rollX, AMPboards,
jcain is offline
post #9 of 11 Old 08-05-2014, 04:49 AM
Your right, they did make some changes to help that situation but the programmer still adds more fuel and timing and that in turn makes the small
Garrett GT-32 Twin ScrollTurbo overspeed which in turn eventually takes out the center bearing. The OP would be much better off changing to a more "robust" turbo such as the Garrett GT-37 or even a Schwitzer S-300 which has been used on some of the Ford SD 6.7 Diesels.
John_P is offline
post #10 of 11 Old 08-08-2014, 04:46 AM
My 6.7L turbo blew at 60K after about 10k miles after i did the delete. had ford put in a new turbo should have upgraded. Is there an adjustment you can make to the turbo for the added boost the programmer gives it?
eniemann54321 is offline
