2012 inverter plans - Ford Powerstroke Diesel Forum
 3Likes
  • 1 Post By Flip123
  • 1 Post By stltikn
  • 1 Post By Hfd137
post #1 of 8 Old 07-28-2014, 07:04 PM Thread Starter
2012 inverter plans
5,000 watt inverter mounted in cab. Two weather proof outlets mounted in bed. One for mid size compressor,one for 110 power tools. Both on individual spring return spools mounted clean and tight near the gate. Thoughts or concerns? Yes, truck running while powering additional equipment.#no-brainer
john galt likes this.
Flip123 is offline
post #2 of 8 Old 07-28-2014, 07:10 PM
Quoted: 20 Post(s)
Be careful where you mount it, as it will produce a fair amount of heat while under high load. Otherwise, it might be best to install some quality SOOW cord to distribute the power. If done right, it will be a nice setup. Good luck with it.
2013 F350 4X4, CCLB, SRW, 6.7, Sterling Gray, Lariat Ultimate, 3.55 ELD, Nav, etc.
Sterling6.7 is offline
post #3 of 8 Old 07-28-2014, 07:21 PM Thread Starter
Too hot for under seat mount? Could do a bed mount with protective cage mod. Good bed cover will keep her dry...
Flip123 is offline
post #4 of 8 Old 07-28-2014, 08:10 PM Thread Starter
Come on guys, 1st time diesel owner. Hit me with what ya got. Buddy said this group of fellow Ford men was the group to listen to.
Flip123 is offline
post #5 of 8 Old 07-28-2014, 08:43 PM
Like Sterling6.7 said, lots of heat will be produced at high load. Make sure you do your research on wire sizing for loads. Might want to install a pancake fan that turns on when in operation. Mounting location will be critical for protection as well as safety. You only want it on when you are using the power. You could mount a remote power switch and mount the inverter in a protected place under the cab. Just some thoughts. Just remember it's not just 12v DC anymore, it's 110AC!!! Be extremly safe with your installation.
The reason I'm saying all this is because sometimes a guy will get all excited about his mod and forget some of the dangers. Good Luck with your project!
Be sure to post pics!!```````````````````````````````````````````` ```````````````````````
stltikn is offline
post #6 of 8 Old 07-29-2014, 02:52 AM
john galt's Avatar
Quoted: 799 Post(s)
I ran a 2k inverter and it powered my tools chargers etc no problem I mounted it to the hump in front on ceramic spacers and never had a problem with it. I did wire in an extra battery just for the inverter, so I could kill it if I needed and still start the truck.
I even ran my fridge and freezer when the power was out for a few days
mount it where it can dissipate heat and you will be very happy.
early 04 f350 6.0 cclb lariat sr
Bulletproof oil &egr, elc, sct x3, edge CTS, afe intake, blue spring, t-500, MTW stage 2, Vivians looney, 305 x55x20 bfg at ko's, 4 inch cat back, 4"BDS fox shocks and steering stabilizer, tri pilar gauge set, sinister coolant filter(this is the ONLY pos sinister product that will ever be on my truck), riff raff boots, new headliner, 7 inch touch screen w/back up, new carpet, near whole new interior,
FederalOwnershipRespectfullyDeclined
john galt is offline
post #7 of 8 Old 07-29-2014, 02:56 AM
Quoted: 51 Post(s)
Personally, I would see if a weather proof inverter is available and mount it in the bed with the outlets. The inverter is going to generate heat. Depending on the in cab location, the heat might be excessive if you operate a 120v tool/source for extended period.
Make sure you check the duty cycle (use time vs cooling time). Install circuit breaker(s) or fuses on the 12v feed to the inverter.
Larry
2015 F350 Ultra Lariat 6.7L CCLB DRW 3.73 Limited Slip, Green Gem Metallic w/ Caribou accent, Camper Package, Titan 65gal tank, Rapid Heat, Block Heater, Upfitter Switches, Dual Alternators, Camper Package, Cable Lock, Husky Floor Liners, Spray in Bedliner, 5th Wheel Prep, 25K 5th Wheel Hitch, Ford Goose Neck Hitch.
Traded 2011 F350 XLT CCLB SRW 6.2L gasser 6,000 miles for 2015
Sold 1996 F350 XLT CCLB DRW 7.3L 208,000 miles
Larry1013 is offline
post #8 of 8 Old 07-29-2014, 11:32 AM
What, no install pics?
FlintRidgeFarmSN likes this.
2011 F350 CCSB Lariat SRW
Readylift 2.5" leveling kit
Western SS MVP3 Plow
Hfd137 is offline
