How much weight before T/H mode? - Ford Powerstroke Diesel Forum
post #1 of 12 Old 07-27-2014, 06:45 PM Thread Starter
Cheap6.7's Avatar
Would like to ask everyone how much weight they think we can haul in the bed before I NEED tow/haul mode? Thanks
Buy American!
Cheap6.7 is offline
post #2 of 12 Old 07-27-2014, 07:06 PM
I wouldn't say there's any magic number where you need tow/haul mode as far as payload goes. Just try it the next time you've got a good load and see if you like it is the best advice I can give you.
claws314 is offline
post #3 of 12 Old 07-27-2014, 07:59 PM
Carli'd6.7's Avatar
Feedback Score: 6 reviews
Haaa this is a fun topic I usually don't engage tow haul till at least 5k+ and sometimes when im going thru neighborhoods or parking lots with a lot of weight ill still keep it off but limit my gears to 3rd or less cuz im deleted and sometimes its just obnoxious holding 2k going thru a parking lot or in my neighborhood at night as im coming home .
**14 F-350 CCLB Lariat w/ HIPS !!**Sinister EGR kit** 4 inch Flow-Pro w/ 36" Magnaflow** H&S XRT PRO w/ SPE Heavy Tow Tune**AFE Stage 2**H&S CAC Kit**Edge CTS gauges**ICON stage 3 2.5 w/ tubular radius arms & 4 inch blocks**4.30 Yukons w/ Trutracs**Firestone ride rites**BW turnover**N-Fab cab Lengths**03.5-04 PSD Badges**20" Fuel Maverick Duals**Mag.Hytec Covers**
Carli'd6.7 is offline
post #4 of 12 Old 07-27-2014, 08:13 PM
uga33's Avatar
All personal preference. It won't hurt anything towing 15k without it or 2k with.
2012 F-350 King Ranch
Spartan Tuning/Flo-Pro/B&W
uga33 is offline
post #5 of 12 Old 07-27-2014, 10:47 PM
T/H mode increases the line pressure allowing for firmer/quicker shifts at an elevated RPM. When loaded down this allows you to accelerate/maintain speed with out the transmission hunting up and down for a gear.
It will do no harm to run the truck with it engaged. I run with it on and my exhaust brake on all the time with my '08 Cummins. When I had the transmission serviced at 105K the diesel mechanic at the dealership was amazed how clean the pan and filter were. He asked me if I had ever had the transmission serviced. I told him how I run and he smiled.
If you run it all the time you will consume a little more fuel and it will shift firmer...not buttery soft. The soft shifting means the clutch packs are slipping longer...causing more wear. Your transmission will also run cooler as the slippage causes heat as well.
The Cummins exhaust break actually pulls down the speed whether loaded or not...also alleviating brake wear. I had the front brake pads changed at 110K...the rears at 161K are still going strong. I've pulled a 14K lbs 5er about 20K of the total miles.
From what I understand, the Ford EB doesn't work the same way...but i could be wrong...
Dougstdig is offline
post #6 of 12 Old 07-28-2014, 05:32 AM
HighHP's Avatar
Up to 2014 the Ford auxillary braking was different and useless. 15+ have the exact same style EB as the Dodge. I find a lot of people prefer the TH mode just for the shift pattern change even for daily driving.
2013 - F350 CCLB. - 8" Lift on 37s. H&S XRT w/ CTS. Sinister EGR Delete. MPD CCV Delete. Wicked Wheel 2. SDP Downpipe. No Limits CAI. 5" FloPro. Retrofit HIDs.
HighHP is offline
post #7 of 12 Old 07-28-2014, 08:17 AM
fordtrix's Avatar
I find that Tow Haul mode helps a lot when decelerating. I tow a 15k+ 5th wheel and it downshifts faster to take a lot off of the brakes.
2013 F250 Lariat CCSB - Firestone Ride Rite, Bakflip F1, B&W 5th Wheel Hitch, Carli 2.5" with track bar, Fuel Maverick 20x9, Toyo MT 35x12.5, Bushwhacker Extend-A-Fender, Weathertech Mats, Recon 3rd Brake and Mirror Lights, PTM Mirror Caps
2013 Crossroads Elevation 3912 - Loaded
fordtrix is offline
post #8 of 12 Old 07-28-2014, 08:19 AM
Quoted: 45 Post(s)
Per 2015 Owner's Manual
Tow/haul delays upshifts to reduce frequency of transmission shifting. Tow/haul also provides engine braking in all forward gears when the transmission is in the D (Overdrive) position; this engine braking will slow the vehicle and assist the driver in controlling the vehicle when descending a grade. Depending on driving conditions and load conditions, the transmission may downshift, slow the vehicle and control the vehicle speed when
descending a hill, without the accelerator pedal being pressed. The amount of
downshift braking provided will vary based upon the amount the brake pedal is pressed.
Larry
2015 F350 Ultra Lariat 6.7L CCLB DRW 3.73 Limited Slip, Green Gem Metallic w/ Caribou accent, Camper Package, Titan 65gal tank, Rapid Heat, Block Heater, Upfitter Switches, Dual Alternators, Camper Package, Cable Lock, Husky Floor Liners, Spray in Bedliner, 5th Wheel Prep, 25K 5th Wheel Hitch, Ford Goose Neck Hitch.
Traded 2011 F350 XLT CCLB SRW 6.2L gasser 6,000 miles for 2015
Sold 1996 F350 XLT CCLB DRW 7.3L 208,000 miles
Larry1013 is offline
post #9 of 12 Old 07-28-2014, 08:21 AM
fordtrix's Avatar
Bingo, great posting.
fordtrix is offline
post #10 of 12 Old 07-28-2014, 10:12 AM Thread Starter
Cheap6.7's Avatar
So let's say 1000lb in bed. I run with T/H on and I'm tuned/deleted, so it shifts firmer natrualy. Am I good to drive without pushing the button?
I feel like it will be fine but I heard you can reck your tranny.
Thanks for replies guys.
Buy American!
Cheap6.7 is offline
