BD High Idle kit - Ford Powerstroke Diesel Forum
User Tag List
post #1 of 19 Old 07-20-2014, 08:44 AM Thread Starter
Dzlbudman's Avatar
BD High Idle kit
Has anyone installed this? I'm about to order one for my 15'. Searched and found one thread but was lacking on info. Thanks for the help.
BD Power - Product: Ford High Idle Kit
16'-Platinum-Pecan-FX4-PSD-Line-X Platinum-B&W-Toyo-Carli-WeatherTech-High Idle Mod-WeatherGaurd Low Pro-
Dzlbudman is offline
post #2 of 19 Old 07-20-2014, 01:10 PM
Steveaux's Avatar
I'm not sure on the 15's although I suspect they haven't changed from 11-14. These trucks already have the provision for high idle in the PCM. It's a matter of hooking up a couple of wires and adding a simple resistor to set the desired RPM. I hooked it up to upfitter 4 and can't remember off hand what value resistor used but it's set to idle at 1200rpm. Works great!
It's a simple quick mod, somewhere down on this thread are instructions. I bet it is the exact same for the 15's.
High idle switch setup
'13 F-350 CCLB SRW 6.7 3E55 4x4
Lariat with all the goodies
Stock for now and plan to keep it that way...mostly
Steveaux is offline
post #3 of 19 Old 07-20-2014, 04:51 PM
Quoted: 3 Post(s)
I installed one in my 14, very straight forward install. Took about 30 min. Works Great.
14PlatinumBlack is offline
post #4 of 19 Old 07-20-2014, 04:54 PM
STX79's Avatar
I get a check engine light every time in use mine, P22FF.
2014 F350 SRW Platinum, Ranch Hand bumpers, AMP Steps, BDS 2" leveling kit, Bilstein 5100 Shocks, 35x12.50R20 Toyo Mud Terrains.
STX79 is offline
post #5 of 19 Old 07-20-2014, 06:45 PM Thread Starter
Dzlbudman's Avatar
Stx. Are you using the BD kit or a build your own kit?
post #6 of 19 Old 07-22-2014, 08:02 PM
STX79's Avatar
I did the Aux switch method.
STX79 is offline
post #7 of 19 Old 07-22-2014, 08:12 PM
If you have the upfitter switches you wouldn't need this kit. If not then go for it.
JohnDS is offline
post #8 of 19 Old 07-23-2014, 03:59 AM
Quoted: 25 Post(s)
There are numerous threads on this site or or the Ford diesel websites on how to do your own High Idle or SEIC.
http://www.thedieselstop.com/forums/...ctures-268611/
They have taken the info from this Ford bulletin and put it in a kit form
https://www.fleet.ford.com/truckbbas...tml/Q180R4.pdf
Many use a 50k potentiometer from Radio Shack to make their own SEIC. I just did this on my 2015. Cost was about $10 to include potentiometer, and wire splices. I got fancy and used wire splices you can pull apart. I also soldered short wires to the potentiometer.
Larry
2015 F350 Ultra Lariat 6.7L CCLB DRW 3.73 Limited Slip, Green Gem Metallic w/ Caribou accent, Camper Package, Titan 65gal tank, Rapid Heat, Block Heater, Upfitter Switches, Dual Alternators, Camper Package, Cable Lock, Husky Floor Liners, Spray in Bedliner, 5th Wheel Prep, 25K 5th Wheel Hitch, Ford Goose Neck Hitch.
Traded 2011 F350 XLT CCLB SRW 6.2L gasser 6,000 miles for 2015
Sold 1996 F350 XLT CCLB DRW 7.3L 208,000 miles
Larry1013 is offline
The Following User Says Thank You to Larry1013 For This Useful Post:
Dzlbudman (07-23-2014)
post #9 of 19 Old 07-23-2014, 04:52 PM
El_Tee's Avatar
That kit looks like a potentiometer that wires into the SEIC the same as if you bought one from Radio Shack and did it yourself. I don't have any experience with that kit, but I know the same thing can be done for a lot less than $57 dollars.
2012 F-250 XLT 4x4 - H&S tuned - Sinister EGR delete - Flo-Pro 5" downpipe back - Method "Mesh" 18x9 - Toyo M/T 35x12.50 - more to come..
El_Tee is offline
post #10 of 19 Old 07-23-2014, 06:59 PM
I wanna do this!
2012 F-250 6.7L 4x4 Lariat CCSB, Titan 51gal, BDS 4" kit with Fox Shox, Toyo AT II 35/12.50R20, Ranch Hands front and rear
2007 F-150 King Ranch 4x4 2" Autospring, Bilstein 5100s on all four corners. Nitto A/T 285s.
2005 Chevy Tahoe 5.3l 2WD
wreedPS is offline
