Oil level - Ford Powerstroke Diesel Forum
 1Likes
  • 1 Post By HighHP
post #1 of 8 Old 07-16-2014, 06:36 AM Thread Starter
Oil level
After running a while on an oil change, I know you guys have noticed an increase of oil on the stick due to the fuel being injected in. Was wondering if any of you guys are draining out some to keep the oil level right on the full mark or just letting it ride?
KENNY
2013 F250 Platinum Tuxedo Black
3.5" Ready Lift
Firestone Air Bags
20x10 BMF Novacane DMB
35x12.50R20 Toyo MT
kennyketten is offline
post #2 of 8 Old 07-16-2014, 06:42 AM Thread Starter
Little more info.... Have 4000 miles on this oil change and was trying to wait till 5000 miles. But the oil level has increased on my dipstick by about 1/16" kind of got me worried that mine may have too much fuel delution to wait till 5000 miles? Trying to wait till 5000 and send off to Blackstone for analysis. Not sure I should wait...
KENNY
3.5" Ready Lift
Firestone Air Bags
35x12.50R20 Toyo MT
post #3 of 8 Old 07-16-2014, 08:03 AM
HighHP's Avatar
You can wait. 1/16 on the stick is nothing. You can always try and suck out a sample and send it in now they are pretty quick to reply.
"Stroker 8" likes this.
2013 - F350 CCLB. - 8" Lift on 37s. H&S XRT w/ CTS. Sinister EGR Delete. MPD CCV Delete. Wicked Wheel 2. SDP Downpipe. No Limits CAI. 5" FloPro. Retrofit HIDs.
HighHP is offline
post #4 of 8 Old 07-17-2014, 03:07 PM Thread Starter
Thanks for your input... just a little paranoid I guess
KENNY
3.5" Ready Lift
Firestone Air Bags
35x12.50R20 Toyo MT
post #5 of 8 Old 07-18-2014, 07:55 AM
TW720HVY's Avatar
Quoted: 2 Post(s)
Our truck calls for 13qts of oil and after a local shop did the oil change they thought there wasn't enough oil in the engine. The oil was just at the base of the range on the dipstick. I showed them in the manual that it does indeed need only 13qts.
After putting a hundred or so miles on it I pull the dipstick again and sure enough it was now in the middle. I called a friend who has the same year truck and he agreed, the oil on the dipstick after a change shows low on his and once he added a quart only to have to drain it back out after awhile.
Maybe someone knows why this is on engines? But in the meantime I do not think your engine is putting fuel in your oil.
Previously Owned
2011 F-350 Lariat Crew Cab, White with Black interior, SRW, Short Bed, FX4
TW720HVY is offline
post #6 of 8 Old 07-18-2014, 08:35 AM
Cheap6.7's Avatar
So my question is is that 13qts after you fill the filter up?
Buy American!
Cheap6.7 is offline
post #7 of 8 Old 07-18-2014, 09:27 AM
Quoted: 37 Post(s)
It is 13 quarts including the filter....See page 57 of your Diesel Supplement Book
If you don't have the Diesel Supplement of Owners Manual you can go here to download them
http://owner.ford.com/servlet/Conten...=header-owners
Larry
2015 F350 Ultra Lariat 6.7L CCLB DRW 3.73 Limited Slip, Green Gem Metallic w/ Caribou accent, Camper Package, Titan 65gal tank, Rapid Heat, Block Heater, Upfitter Switches, Dual Alternators, Camper Package, Cable Lock, Husky Floor Liners, Spray in Bedliner, 5th Wheel Prep, 25K 5th Wheel Hitch, Ford Goose Neck Hitch.
Traded 2011 F350 XLT CCLB SRW 6.2L gasser 6,000 miles for 2015
Sold 1996 F350 XLT CCLB DRW 7.3L 208,000 miles
Larry1013 is offline
post #8 of 8 Old 07-18-2014, 11:02 AM Thread Starter
This is correct, I buy 3 gallon jugs and 1 quart bottle. The quart bottle goes in the new filter and the 3 one gallon jugs go in the top. After latting it idle for a few minutes and rechecking the oil is spot on the full mark. I was just concerned of having to much over a few thousand miles due to the fuel dilution with the regen processes. Was wondering if it were ok to let it ride or would it be better to drain a little out.
KENNY
3.5" Ready Lift
Firestone Air Bags
35x12.50R20 Toyo MT
