Tailgate hard to open - Ford Powerstroke Diesel Forum
 1Likes
post #1 of 15 Old 07-14-2014, 06:59 PM Thread Starter
Quoted: 2 Post(s)
Hello,
My tailgate is really hard to open, I have to pull way up on the lever to get it to release. If I open it up, what do I need to look for to adjust this?
2012 F-250 6.7L 4x4 Lariat CCSB, Titan 51gal, BDS 4" kit with Fox Shox, Toyo AT II 35/12.50R20, Ranch Hands front and rear
2007 F-150 King Ranch 4x4 2" Autospring, Bilstein 5100s on all four corners. Nitto A/T 285s.
2005 Chevy Tahoe 5.3l 2WD
wreedPS is offline
post #2 of 15 Old 07-14-2014, 07:07 PM
Yeah it's a Turbo Diesel
mts678's Avatar
Quoted: 6 Post(s)
Feedback Score: 12 reviews
Originally Posted by wreedPS View Post
Hello,
There's little plastic clips that screw onto the levers, unclip them and tighten or loosen them for adjustment. That should do it.
Sent from AutoGuide.com App
Marshall
2000 F250 7.3L CCSB 2WD
Tinted | Focal speakers & 12" Kicker | CTS Edge Insight | Wicked Wheel | 6 pos chip | 05 grill & lights | 08 mirrors & tailgate | EBVP delete | 08 console | Nathan P3 train horns & Onboard Air
Switching to hid's? Do it right!
mts678 is offline
post #3 of 15 Old 07-14-2014, 07:09 PM Thread Starter
Quoted: 2 Post(s)
Is this on the handle?
wreedPS is offline
post #4 of 15 Old 07-14-2014, 07:18 PM
POWERCHOKER
Dantron's Avatar
Did you look in there yet? I removed the plastic liner on the inner side of the tailgate and I was able to see all them handle giblets. You can probably see what's causing it from there..
Dantron is offline
post #5 of 15 Old 07-14-2014, 07:20 PM Thread Starter
Quoted: 2 Post(s)
No Ill check it out tomorrow.
wreedPS is offline
post #6 of 15 Old 07-16-2014, 02:34 AM
Ontario Trucker's Avatar
Just get a big hammer, that'll open it
Gerry..... 2006 F350 Lariat, white
Ontario Trucker is offline
post #7 of 15 Old 07-16-2014, 05:02 AM
Cheap6.7's Avatar
Thanks to this thread I got mine juuuuust right. Thanks
Buy American!
Cheap6.7 is offline
post #8 of 15 Old 07-16-2014, 05:38 AM
RJC2's Avatar
Quoted: 134 Post(s)
Okay OT, I have whapped it and whapped it with my biggest hammer and it dents but still won't open. What next?
Dantron likes this.
2002 F250 ECLB, XLT, 7.3 PSD, 4X4, Auto, TW 6pos. Tuner, 4" SS Exhaust, Britebox, EZ Down tailgate assist, Rear Air Bags, 6.0 trans cooler, Wicked Wheel 2, Corey's HPX, Dieselsite Water pump w/built-in filter, 203 degree thermostat, Max A/C assist, Oil drain valve, Non EBV pedestal & Flange, S.S. bellowed up pipes, Dieselsite Lifetime Rad. hoses & Intercooler hoses, New oil cooler, CTS Insight monitor,
Sold - 2014 F250 CCSB, Lariat Ultimate 6.7
RJC2 is offline
post #9 of 15 Old 07-16-2014, 08:05 AM
Pull up on the handle..........
post #10 of 15 Old 07-16-2014, 08:06 PM
Quoted: 11 Post(s)
Sometimes the screws on the catch assembly work loose. Look at the edge of your gate where it engages the post from the bed. make sure those two screws are tight and the assembly the hold is tight. If they get loose and wiggle, then almost not amount of lifting on the handle will open the gate.
2015 F350 CC SRW LWB Lariat, Leveled, BAKflip, Ultra Predator wheels with Toyo A/T 295/65R20, Firestone Airbags and onboard compressor
2011 F350 CC SRW LWB Lariat - Gone
Painted Horse is offline
