Be careful who you tell!!!!!! - Ford Powerstroke Diesel Forum
User Tag List
post #1 of 12 Old 07-14-2014, 05:55 AM Thread Starter
IronCobra's Avatar
Quoted: 8 Post(s)
So, a friend of mine installed the Pop-n-Lock tailgate actuator on his new 2014 f250 KR thinking it would make his truck more secure. He not only told everyone on a particular forum, but also showed half of the neighbors who were out that day during the installation. What he didn't realize was that he was also showing everyone how easy it is to break into a truck with this upgrade.
The next day, all his tools were stolen because some smart guy cut the wires under his truck and used a 9vt battery to trigger the unlock of his tailgate.
So, if you have this upgrade, you either need to stay hushed about it or run your wires soooo well that this can't happen easily.
This is probably true of several upgrades you may have. Including the Jimmi Jammer.
2016 F450 Platinum FX4 CC LWB
2016 Chaparral 360IBL Fifth Wheel: 15,500lbs
GONE - 2011 F250 FX4 6.7L Lariat Ultimate
IronCobra is offline
post #2 of 12 Old 07-14-2014, 06:27 AM
POWERCHOKER
Dantron's Avatar
I will certainly avoid this upgrade now. There's no reason to have a remote tailgate lock anyway. Lock your tailgate manually after every use...
Dantron is offline
post #3 of 12 Old 07-14-2014, 06:32 AM Thread Starter
IronCobra's Avatar
Quoted: 8 Post(s)
When I use to install alarm wires on jeeps back in the day, I would actually use either galvanized steel or electrical PVC to hide the entire run. I would then disguise the wires in a bundle of additional fake wires. I would then wrap the conduit in a rubber adhesive undercoating. If I end up running the pop n lock, I would do this same approach. Sure it will add about 2hours to the install, but it would make hacking into the wires virtually impossible or at least extremely time consuming.
post #4 of 12 Old 07-14-2014, 04:19 PM
POWERCHOKER
Dantron's Avatar
I almost bought me a set of Jimmi Jammers while back. Are they even worth a dingley hoot?
Dantron is offline
post #5 of 12 Old 07-14-2014, 04:26 PM
ZMANN's Avatar
Quoted: 509 Post(s)
i am pretty sure it would be easier to snap the handle off of the tailgate ?
but if he was thinking while he was running the pop n lock wire he should have added a tail gate switch for the alarm he should already have
its also handy to use with a tailgate open light so you don't drive off with it down by accident
Dan jimmy jammers just lead to more door damage before they pop your window glass IMHO
06 KR 4x4 BPD remote OEM Oil cooler /EGR cooler/water pump6 phase FICM , ARP studs,
Rize 4 link Toyo 37" camper modified special
For a truly terrible firearm experience I suggest Taurus
ZMANN is offline
post #6 of 12 Old 07-14-2014, 04:37 PM
Quoted: 30 Post(s)
A lock will only keep an honest person honest. If anyone has any ulterior motives, they will find a way to steal/break into what ever is being secured by a lock.
Larry
2015 F350 Ultra Lariat 6.7L CCLB DRW 3.73 Limited Slip, Green Gem Metallic w/ Caribou accent, Camper Package, Titan 65gal tank, Rapid Heat, Block Heater, Upfitter Switches, Dual Alternators, Camper Package, Cable Lock, Husky Floor Liners, Spray in Bedliner, 5th Wheel Prep, 25K 5th Wheel Hitch, Ford Goose Neck Hitch.
Traded 2011 F350 XLT CCLB SRW 6.2L gasser 6,000 miles for 2015
Sold 1996 F350 XLT CCLB DRW 7.3L 208,000 miles
Larry1013 is offline
post #7 of 12 Old 07-14-2014, 05:14 PM Thread Starter
IronCobra's Avatar
Quoted: 8 Post(s)
That's true, but what I've discovered is that thieves are generally pretty nervous and time conscious while committing their hanus acts. If you can foil the original attempt to gain entry then you can usually deter them. Case in point, you are much more likely to have an unlock car broken into and a locked car. Or for that matter, a car with a window down will get robbed before one that is secured. It's low hanging fruit. All you are trying to do is make you car less accessible during a theft attempt. Create a scenario that makes a thief think he is taking too long. Easier targets are always out there.
I think the jimmi jammer is probably a great idea, it causes confusion and delay and extra time needed to access a vehicle. All of those help thieves move onto easier targets. But true, a determined theif will get in regardless. Fortunately determined and theif don't generally go in the same sentence (unless trying to get out of a building with safety glass).
post #8 of 12 Old 07-14-2014, 06:39 PM
POWERCHOKER
Dantron's Avatar
I quit shopping around for Jimmi Jammers after realizing my truck was essentially impossible to steal and I would only be adding extra protection towards a smash-n-grab job, which can be achieved without disabling the door locks. I did go with Viper security tint for my windows, but the actual effectiveness is uncertain. I tried to smash my window using a tailgate hitch in the past and I was amazed at the resilience after several attempts...
Dantron is offline
post #9 of 12 Old 07-15-2014, 05:30 AM Thread Starter
IronCobra's Avatar
Quoted: 8 Post(s)
Good luck breaking out of your truck through the window if you ever end up in the drink.
post #10 of 12 Old 07-15-2014, 08:24 AM
k7lvo's Avatar
True that! I think I'd shoot it out...
Lewis
2014 F-250 XLT CCSB 4X4
k7lvo is offline
