Tire Pressure - Ford Powerstroke Diesel Forum
post #1 of 2 Old 06-30-2014, 06:50 PM Thread Starter
Tire Pressure
I got a set of 275/65/20 Nitto Terra Grappler's on my 2015. I do pull a 8500lb camper now and then.
What pressure should I be running? Running 65lbs now and the tires are noisy and have an odd sound.
Truck had 18's on it stock.
ryanbrew is offline
post #2 of 2 Old 06-30-2014, 07:54 PM
You're just fine on pressure at 65 psi. I ran that exact same tire and size and had a little noise. I now run the same tire in a 295/60/20 and it's significantly louder. These tires just make a little noise unfortunately but I can tell you I've had good luck out of them as far as wear and tear goes.
claws314 is offline
