Random questions mostly suspension - Ford Powerstroke Diesel Forum
post #1 of 43 Old 06-30-2014, 10:59 AM Thread Starter
Carli'd6.7's Avatar
Feedback Score: 6 reviews
So i took the new rig on a 600 mile trip last night COMPLETELY EMPTY 40 PSI in both duals and 70 in the front and holy crap it rides terrible on some freeways. Talk about a bull ride it reminded me of being on my old long 24v long bed cummins. Which leads me to some questions
Is this just the factory Rancho's everyone complains about ??
Back in the day we used to just take the rear sway bars off our dodges and that helped alot with off camber freeways and just smoothness all together has anyone done this??
Should just just put a full Carli Kit on this truck leafs and all with bags and run 19.5??
What is the largest tire you can put on a stock dual ?? and i dont mean squeezing a 12.5 on there i mean workable with no spacers like 265 285 ??
**14 F-350 CCLB Lariat w/ HIPS !!**Sinister EGR kit** 4 inch Flow-Pro w/ 36" Magnaflow** H&S XRT PRO w/ SPE Heavy Tow Tune**AFE Stage 2**H&S CAC Kit**Edge CTS gauges**ICON stage 3 2.5 w/ tubular radius arms & 4 inch blocks**4.30 Yukons w/ Trutracs**Firestone ride rites**BW turnover**N-Fab cab Lengths**03.5-04 PSD Badges**20" Fuel Maverick Duals**Mag.Hytec Covers**
Carli'd6.7 is offline
post #2 of 43 Old 06-30-2014, 12:55 PM
Randy_270's Avatar
Quoted: 2 Post(s)
How many leafs are in the dually leaf pack? I thought you didn't like the full Carli leaf springs you had in your 2013? Why not just changed out the shocks and lower your tire pressure when not towing and see how much that helps? As for you tires, go measure the distance between your duals and see how much room you have. That should help you decide on what size tire to run. I didn't like the ranchos because they didn't last long, that's my complaint. A dually has the heavy duty rear springs so good luck getting it to ride nice in the back
2011 F350 Lariat FX4, CCSB, 6.7, 3.55s, 325/65R18 Duratracs, Carli 4.5" Pintop, Flo-Pro, S&B intake, H&S w/ SPE tuning.
2011 Explorer Limited 4WD on 17x7.5s Core Racing Diablo 2s with 245/70R17 Duratracs
Randy_270 is offline
post #3 of 43 Old 06-30-2014, 03:18 PM
Bfg makes a 255/80R17 mud terrain that is supposed to work. I would think 19.5s would make the ride worse. Cheapest fix would be some weight in the bed. I doubt shocks will make any difference. It's those stiff springs giving you a stiff ride. Do you need 70psi up front or can that be lowered?
ToyHoarder is offline
post #4 of 43 Old 06-30-2014, 03:29 PM
Also I think there are dually wheels with additional offset between the duals. Ultra gauntlet maybe?
post #5 of 43 Old 06-30-2014, 04:08 PM
wrecker's Avatar
I've got a 14 350 drw, I had the same complaints as you about it stock, so I put the carli 2.5" pintop kit on it with the mini packs in the rear and the longest leaf of the mini pack removed cause it doesn't fit. It rides EXACTLY the same after the carli kit install, no difference in ride at all. If I was to do it again I would just keep the rancho's and add a spacer block for the leveling kit and save a crap load of money. The only thing that's going to improve the ride is swapping out the entire leaf pack, but then even with a full carli leaf pack and airbags I believe you are only upto the load carrying capacity of a stock srw 350 spring (which is less than a stock drw), which defeats the whole purpose of having a dually in the first place aside from the extra stability while towing. I put 2000 miles on my truck with everything stock and just the carli kit and the ride was still just as bad as stock. I'm now running 37" toyo's and 22" 10 lugs and it's even worse, but I haven't had time to adjust air pressures yet and they are all at 60psi which is way too much.
14 F350 DRW Platinum, Carli Pintop 2.5", 37" Toyo's, 22" 10 Lugs, H&S
wrecker is offline
The Following 2 Users Say Thank You to wrecker For This Useful Post:
Bakken64 (07-01-2014), layson (07-01-2014)
post #6 of 43 Old 06-30-2014, 05:30 PM
LORD OF WAR
nelson1each's Avatar
Feedback Score: 4 reviews
Oh you have a different truck now...better put something carli on it or you'll need a name change!
87,96,04 F150 gone
2011 F250 6.7L SC Lariat 4x4
"The War Wagon"
5" Flo Pro w/muffler, SDP downpipe, Sinister EGR delete, S&B intake, H&S mini maxx w/ SPE HotX, H&S intercooler pipe, MPD CCV Mod, Top Gun Customz 6" Lift, TGC dual steering stabilizer w/ night hawk shocks, TGC ladder bars, Night hawk 2.65 resi shocks, BMF rehab 20x9 rims with 5" backspacing (0 offset), Nitto Trail Grappler 37x12.50x20 tires, SSBC calipers w/Big Bite rotors front & rear, SPE metal oil pan upgrade & full diff lock, Mag-hytech dif cover, Deezee headache rack, Bushwacker fender flares & shocker 540 train horns.
nelson1each is offline
post #7 of 43 Old 06-30-2014, 06:54 PM
I have just the carli starter kit with the bilstein's and it rides great.. my buddy has the kit with the king shocks and its rougher the h*ll
Bopper is offline
post #8 of 43 Old 06-30-2014, 07:27 PM
Motor Head.
robertc68's Avatar
Quoted: 18 Post(s)
This is sort of funny because my truck is a 2004 f350 dwr and I have been wondering how the new trucks ride.My truck is better but is rough .I have converted the front to 05 and up coil springs and have just put 2011 f350 srw leafs in the back,while it is better,it's still not as good as I would like it to be.I want to see what you do to improve your ride.Nice truck I would like to have a new one in time.
04 350 DRW CC LB,4:10,245/75/17,tires 4X4..Coolant filter. CTS.Stage II AFE.EGR Delete,Zoodad ,regulated return, ,Arp,OemHG,AD150,WPE ported int,58FICM,190/30 Injec,05 coil conversion.WPE/KC 1.5 turbo,2011 rear leafs,13 tailgate,flight fab trac bars.2014 Power/folding/Extend mirrors.
robertc68 is offline
post #9 of 43 Old 07-01-2014, 07:44 AM Thread Starter
Carli'd6.7's Avatar
Thanks for all the input my truck is almost never emtpy we are just on a family vaca doing the sea world and San Diego zoo and beach thing so the heaviest thing I got on board is a BMX bike and a razor scooter buuut I did run to home depot and grab 500 lbs of sand for the ride home so everyone can sleep the radio only drowns out so much
post #10 of 43 Old 07-01-2014, 07:46 AM Thread Starter
Carli'd6.7's Avatar
That's been my experience I had the pintop on my SRW and rode better off road then on road it sure did look pretty tho
