Fuel filter change from a 6.7 newbie - Ford Powerstroke Diesel Forum
 2Likes
  • 2 Post By rossmelvin
post #1 of 4 Old 06-28-2014, 09:41 AM Thread Starter
Did my first fuel filter change at just over 11k. Pretty easy process. Unscrew the Fuel conditioner bowl 3 turns before you unscrew the yellow drain. I got about 3/4 of a large mason jar of fuel. Finish unscrewing it, pop the new one in. Put the new o-ring in, screw it all back together then plug the water sensor back in. The under hood filter was the easiest, pop the two connectors off, 1/4 turn. And reverse the process. PS don't do this just after driving, the fuel was pretty dang hot.
Also I only did 2 key cycles, herd lots of bubbling from the tank. When it stopped turned the key to start and it started right up!Fuel filter change from a 6.7 newbie-image.jpg
14 F350 CCSB Silver w/ two tone Gray, 6.7 Powerstroke, 4x4 3.55 ELD, Lariat Ultimate, FX4, Cab lights, Rapid heater, Block heater, up fitters, and 20s.
http://instagram.com/p/pASINcPOxn/
rossmelvin is offline
post #2 of 4 Old 06-28-2014, 09:44 AM Thread Starter
Here's the other pic.
post #3 of 4 Old 06-28-2014, 12:45 PM
just did mine this morning, was really easy. Paid $68 for the filters at my local dealership, im sure they are cheaper online but was in a rush, im leaving for out banks tonight.
2012 F350 CCSB 6.7 Lariat
automoto is offline
post #4 of 4 Old 06-28-2014, 12:50 PM Thread Starter
The local stealership in Birmingham wanted 95 bucks. Got them here instead Ford 6.7 liter Powerstroke Turbo Diesel Truck Filters - Diesel Filters,Additives,brake rotors, and brake pads for Chevy, Dodge and Ford Diesel Trucks
"Stroker 8" and JarWoo like this.
